Ignition Coil Charge Time
Old Dec 10, 2015 | 12:38 PM
EvilEvolution8's Avatar
Hello,
What difference between the 3 items in ROM 96530706 (TephraMOD v7 Evo 8) :
- Ignition Coil Charge Time
- Ignition Coil Charge Time (Unknown 1)
- Ignition Coil Charge Time (Unknown 2)
I read in another post that the formula to convert "units" to "ms" is : x*64/1000.
Seems correct but the value is more different that the "dwell" settings that SparkTech send with Non-CDI COP.
Someone can tell me the best values for COP ?
Regards
Old Dec 12, 2015 | 07:26 PM
CDrinkH2O's Avatar
These settings work well for my Spoolin Up COP:
(Although the names are different to your tables, they are actually the same).
Make sure you replace the ignition circuit 10 amp with a 15 amp fuse before you use these otherwise you may blow it.
More details here: https://www.evolutionm.net/forums/ec...-behavior.html
Old Dec 13, 2015 | 04:57 AM
Thanks a lot!
I just replaced the fuse with a 20amp one!
Old Dec 13, 2015 | 10:58 AM
CDrinkH2O's Avatar
That should be fine. The Toyota 90919-02240 coils in my COP set up limit maximum current to 12.5 amps. Most coil on plug setups have current limitation built in to prevent you from unintentionally melting them. Even so you would be wise to check the coil head temperatures after driving them for the first time
, just to make sure they are not getting too hot.
Old Dec 13, 2015 | 11:00 AM
Ok perfect!!!
Thanks a lot...i will try and check
Old Dec 13, 2015 | 02:13 PM
todd6027's Avatar
if you want to change coil charge time to ms add this to xml then edit the def in ecuflash
Old Dec 13, 2015 | 02:15 PM
todd6027's Avatar
disappears when i post it
Old Dec 13, 2015 | 02:16 PM
What XML?
Old Dec 13, 2015 | 02:26 PM
Hahahah great!!! Can you send it via PM?
Old Dec 13, 2015 | 02:32 PM
CDrinkH2O's Avatar
96530706.xml attached with mrfred Coil Dwell additions
File Type: xml
Old Dec 13, 2015 | 02:34 PM
todd6027's Avatar
gotcha
Code:
  <scaling name="CoilDwellTime" units="ms" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.32" inc="0.064" storagetype="uint8" endian="big"/>
chetrickerman
Oct 24, 2014 03:31 PM
stunt2
Feb 12, 2012 03:22 PM
Thugline
Aug 11, 2010 01:55 PM
knochgoon24
Apr 6, 2010 07:35 PM
Boost3dxEvO
32
Sep 23, 2008 04:22 AM
