Omni 4 bar scaling
Old Mar 19, 2018 | 02:13 PM
foxbat's Avatar
Omni 4 bar scaling
Anyone got good calibration numbers for the Omni 4bar map sensor? The car idled & cruised terribly with my current table!
MAP(KPA) Load%
0.0----------------0.0
67.6--------------50.4
122.2------------108.8
202.8------------151.2
270.4------------201.6
340.4------------252.0
405.2------------302.4
472.8------------352.8
Old Mar 21, 2018 | 06:02 AM
mines5's Avatar
MAP(KPA) Load%
Which injectors ? i have 2150s . I am in office ,i ll share them as soon as i reach home.
Old Mar 26, 2018 | 05:21 AM
foxbat's Avatar
I'm using RC1200CC
Old Mar 28, 2018 | 11:30 AM
jmedina23's Avatar
mines5,
how you table looks like? I would like to compare with mine.
Old Apr 1, 2018 | 06:48 AM
mines5's Avatar
Sorry for the late reply Guys.
Finally got time to post. This is on Simple SD , not 3D VE.
S2 Cams . 32 Psi , pump gas.
Old Apr 1, 2018 | 06:54 AM
mines5's Avatar
MAP(KPA) Load%
Brother, i think your load is very low for all the conditions.
Vacuum and boost both.
Old Apr 2, 2018 | 12:10 PM
jmedina23's Avatar
mines5,
Thanks for the information. I have attached my latest ROM data which I still working on it. My LTFT (low and mid) are shown in very good shape as per the evoscan file but I'm still experimenting some jitters up to 3000RPM. This still a work in progress....anyfeedback will be appreciated as well. I have 8859 ROM, FIC 2150, 2.0L 6466 Turbo 2 pumps, -8an (main) & -6an ( Y connection to fuel pumps) fuel lines.
Old Apr 4, 2018 | 10:43 AM
mines5's Avatar
Originally Posted by jmedina23
mines5,
Are you running E85 ? Such a co-incidence you are running almost the same setup as mine. Which cams do u have?
At what RPM do you get Full boost ?
For jitters people are using radium fuel pulsation damper with radium fuel rail. I haven't installed one yet.
Jitters are also because of triple / twin plate clutches under certain conditions.
Old Apr 5, 2018 | 07:33 AM
jmedina23's Avatar
mines5,
Yes, I'm running E85. I have S3 cams. I did pull some data yesterday to see if the SD VE Table and kpa vs load needed to be modified. Today I will get into the details of the data to see what could be happening between the 1k-3kRPM. See the video I took from yesterday cruising at 5th year low RPM. BTW I was looking at the data yesterday in the live map of EVOSCAN and seems to be weird my %load at 35% throttle opening was over 300% with no boost at all. Another thing I will be researching today. I have a Quartermaster Clutch which cause a lot of inertia taking off. With the issues I'm having in low RPM's is a little bit difficult to handle.
https://drive.google.com/file/d/1sxm...ew?usp=sharing
I can't find the graph the shop that build the car sent me but the car made 630WHP @ 25psi on E85 (previously the car made 852WHP @ 43psi I think with the old owner - I will open a new thread with the whole story). I'm working in the cruising and idle issues which I have solve part of them to then move toward the WOT to see how everything is looking( I think will need some work judging the idle condition that the shop gave me the car). It is kind of fun mess with this car man. I have an AEM V2 brand new that I might end up installing as soon as get these things figured out.
Still a lot to research but again is fun man see how couple guys have figure this ECU and mess with everything to make us "easier" the tuning process. They know how to reverse engineer this type of thing.
Old Apr 5, 2018 | 09:52 PM
mines5's Avatar
mines5,
I also have Quarter Master 6 Leg, I think that jitter is more pronounced because of the Clutch. Another friend of mine using EXEDY Twin plate doesnt get these jitters.
Benja
Jul 3, 2019 12:42 PM
RelentlessEVO
Feb 9, 2017 01:34 PM
todd6027
Apr 14, 2014 12:29 PM
Evoleader88
Dec 8, 2010 07:46 AM
murlo26
11
Apr 2, 2010 11:04 AM
