help me decipher my tune
Old Apr 2, 2018 | 08:09 PM
nor11384's Avatar
FCOTM Winner
Hey guys I posted this in general forum but it was suggested I post it over here so some of you tuning gurus could help me out. Ok guys, ive been having an issue for the last couple weeks where my car idles and cruises rich as hell. Idle 11.5 - 12. Everything has been done and checked. This started after doing headgasket, arp headstuds, gsc s2 cams, gsc springs/retainers. My tuner says only way he could lean it out was scaling injectors which are stock. Car is 04 evo 8, evo 9 turbo, gsc s2 cams with springs/retainers, speed density, and bolts ons. I'm having a member from the forums check the tune but was wondering if you tuning gurus could take a look. Maybe something will catch your eye that would explain this situation. Keep in mind car had a cylinder with low compression on this tune so now that its fixed this may have affected it. Fuel trims on evoscan are not reading. I installed a denso o2 sensor from auto parts but nothing. Ive spoke to some guys that said it has to be factory o2 sensor because others don't work as well. Would really rather not spend $350 on that right now but if I have to I have to. Let me know what you think guys.
File Type: bin
Old Apr 10, 2018 | 03:39 AM
evo8vz's Avatar
You could try scaling injectors from 513 to 543
but took off about 7% from idle in your ve table hope it works but you should prob pay your tuner the 350.00
Old Apr 10, 2018 | 03:41 AM
evo8vz's Avatar
here is the rom fyi
took fuel out in cruising areas too
File Type: bin
Old Apr 10, 2018 | 09:26 AM
jmedina23's Avatar
Originally Posted by evo8vz
here is the rom fyi
What definition are you using to open the ROM? I'm getting some errors. I would like to take a look at it.
Thanks!
Old Apr 10, 2018 | 11:03 AM
evo8vz's Avatar
its a regular 2d sd rom
Old Apr 10, 2018 | 11:31 AM
nor11384's Avatar
FCOTM Winner
I figured out it was the ve tables and o2 sensor. I think I'm missing some stuff on that rom. Guys what is the difference between sd 1.0 and 2.0? Ive been reading a lot on 2.0 and the 3d tables. Is it better? Do any of you guys have experience with it? Is it worth switching? Also, I thought scaling stock injectors was a big no no?
Old Apr 10, 2018 | 04:54 PM
evo8vz's Avatar
Originally Posted by nor11384
I figured out it was the ve tables and o2 sensor. I think I'm missing some stuff on that rom. Guys what is the difference between sd 1.0 and 2.0? Ive been reading a lot on 2.0 and the 3d tables. Is it better? Do any of you guys have experience with it? Is it worth switching? Also, I thought scaling stock injectors was a big no-no?
some evo use 543 scaling which should lean it out but if your o2 is bad replace it or go full time open loop...
Old Apr 11, 2018 | 09:32 AM
nor11384's Avatar
FCOTM Winner
Replaced o2 sensor but had a lean tip in issue so it’s open loop now and tuning it like that first then putting it in closed loop to see what it does.
nor11384
21
Apr 6, 2018 05:42 AM
VerbalKilla
Nov 24, 2014 09:16 AM
VerbalKilla
Nov 22, 2014 01:57 PM
Jim in Tucson
Jun 13, 2007 10:38 PM
Ralph
Sep 16, 2006 08:31 AM
