Definitions
Old Jan 6, 2020 | 04:14 PM
Warhawker's Avatar
Definitions
I got all my cables in today finally, and hooked everything up. I started with just reading the ECU, however I pulled a ROM image the ECUflash does not have a definition for.
I'm a little confused because I can't find the ROM id anywhere in order to get the definition file. The only bit of information I could gather was the "Memory Model"
I've done a bit of searching as I'm sure others have had the same issue, but everyone else seems to have a ROM ID to work with.
Any insight?
I have a 2010 X SST, using Openport 2.0. The car has been previously tuned, and I'm fairly certain it has tephra as well.
*Edit
I went further and specified to create a definition, and chose to inherit one of the 4 USDM '10 EvoX options. Just for the fun of it, I tried all 4, and got the same ID 55580306
This would seem to agree with Tephra being installed already.
However I can't find an XML for this ID using google. Should I search for an XML with 55580006?
*Edit2
So I told ECU flash to inherit 55580006, which was already in ECUflash's library, but I still can't see any of the properties of my current map. I'm not sure where to go from here :\ I'm just trying to read what's on the car, and make a few changes. I also made sure I installed the registry edit that allows me to flash v3.
Old Jan 6, 2020 | 07:38 PM
RazorLab's Avatar
Any insight?
*Edit
*Edit2
send me a PM, I can help
Old Jan 6, 2020 | 08:12 PM
Warhawker's Avatar
Thanks, I sent you a message.
StarWolf
Jan 11, 2016 07:20 AM
tim85851
Sep 30, 2013 12:12 PM
Piro Fyre
Jul 15, 2011 05:54 PM
onboost
Jun 26, 2009 09:15 PM
onboost
Jun 26, 2009 06:04 PM
