Boost cut, fuel cut or anything else
Old Mar 21, 2020 | 12:40 PM
Fuchsig's Avatar
Hello
I use Tephra 9653 rom with Tactrix 3 Port BCS.
I already installed my fp red during winter. I started with WGDC 0% and BDEL off. The Turbo works fine. I increased the WGDC a little, which works well until 6000rpm, then the IPW drops, Boost drops to zero at 6600rpm, the maximum load is 240. I use x1 Fuel/Boost cut, the value are set on 300.
Does anybody have an idea, where the problem is?
Picture 1 – WGDC 0% - Boost at 6500rpm is higher than WGDC 60%
Picture 2 – WGDC 30-60%
Thanks and best regards
Marcel
Old Mar 22, 2020 | 10:59 AM
wreckleford's Avatar
A big boost leak? Wastegate flapper blowing open?
Old Mar 27, 2020 | 03:05 AM
400s's Avatar
Upload the log.
Old Mar 29, 2020 | 11:55 PM
OzAirtrek's Avatar
Log your 2 byte load - your probably hitting 300 load and getting fuel cut
Old Mar 30, 2020 | 10:22 AM
Fuchsig's Avatar
Thanks for answering me.
I did a Boostleaktest. Three little leaks and my MR BOV blew off early. I changed my bov today and closed the leaks. No change. I already drove with x2 and max fuel cut. No changes.
I use 2byte to 1byte Load Factor 1.2 with Evoscan and log Load 1Byte with Factor 1.2*x. There’s something wrong with that?
Attached my log and rom.
File Type: bin
peisden
Apr 12, 2015 03:29 AM
catman78
Oct 3, 2011 07:51 PM
kiwiracer
Aug 19, 2011 02:58 PM
foxbat
Aug 1, 2011 01:20 PM
xmaciek82x
Mar 28, 2010 11:57 PM
