2012 GSR Rom image not found
I recently traded in my 2016 WRX for a 2012 evo gsr, the car is pretty much FBO and has been tuned. I went to try to read the ecu and it will read it but says the rom definitions arent available. Im having trouble figuring out what definitions i would need to put in the rommetadata folder. Ive used Ecuflash before with my WRX but that ecu was still factory stock when i first read it. I tried to attach the attempt to read but not sure if it worked or not. Can anyone help me figure out what i need to do?
The ROM ID is 58018005. You can see the rom id at the address of 0x5002a.
Perhaps someone who tuned your evox set a unique ID(58018005) at that time.
So, if you have 5801005.xml, you can edit the contents.
Download attached 58018005.xml, and save it into 'My Documents/ecuflash/rommetadata/mitsubishi/evo/' folder.
(If you don't have 58010005.xml, download it from Bryan's site and save it into 'My Documents/ecuflash/rommetadata/mitsubishi/evo/' folder.)
Then try opening your rom with echflash.
(I mean move the file from your downloaded folder to 'My Documents/ecuflash/rommetadata/mitsubishi/evo/' by Explorer or so.)
If you don't have 8010005.xml in that folder, also download 80100005.xml from Bryan's site and just place it into the folder.
No need to edit the .xml I attached. Just download it and place it into 'My Documents/ecuflash/rommetadata/mitsubishi/evo/' folder.
Just note that the fix to 80100005 is not automatically reflected in 80108005.
Travis Dralle
Jul 31, 2017 09:51 AM
