Need Help could someone check this log for me?
Old Mar 29, 2021 | 11:08 PM
jrsimon27's Avatar
Hi friends could someone help me with this log.
We are trying to tune an evo8 rs jdm model it has a bbk turbo boost is set at 28psi. The thing is that when the car hits 5500rpms it bogs down afrs go lean for a moment and then it gets going.
It has been checked for boost leaks it has none also spark plugs and cables are new.
What can it be what do i check?
THANKS.
Old Mar 30, 2021 | 07:39 AM
Biggiesacks's Avatar
What gap are you using on the plugs?
Old Mar 30, 2021 | 09:45 AM
Project_Broke's Avatar
THANKS.
Post your map, you go from 2 degrees of advance around 5400 to 18 at 55ish. Something isn't right. Timing is super low, then way too high.
Also looks like Load isn't logging.
Edit: You have 0 injector duty cycle when it cuts out. Stop going into boost until you figure this out or it'll go bang.
Old Mar 30, 2021 | 10:00 AM
jrsimon27's Avatar
0.19
Thanks.
jrsimon27's Avatar
ill post it up give me a chance.
thanks.
Old Mar 30, 2021 | 07:35 PM
jrsimon27's Avatar
here its the rom of the timinig.
Old Mar 30, 2021 | 07:36 PM
jrsimon27's Avatar
car has bbk turbo 1000cc rc injectors and walbro 255l fuel pump.
Old Mar 31, 2021 | 04:12 AM
There's some large timing jumps here, but nothing that would cause what I saw on the logs. It does need smoothed and some timing taken out here or there.
PM me the ROM file if you'd like. I'll run through it.
Old Mar 31, 2021 | 07:15 AM
RazorLab's Avatar
According to the log, the car is running 240-220 load. Make sure your boost cut is higher than that. However, from the log, it looks like spark breakup.
Here is the log on Datazap to make it easier for people to see: https://datazap.me/u/razorlab/evo-8-...1&zoom=882-982
Old Mar 31, 2021 | 07:28 PM
jrsimon27's Avatar
thanks razorlab here is the image of the boost limit.
jrsimon27's Avatar
thanks i sent you a PM
noubey27
16
May 18, 2015 06:48 AM
prostcj
Nov 25, 2011 06:38 PM
xexitenglishx
Oct 18, 2010 09:50 AM
pileofparts
E85 / Ethanol
Apr 9, 2008 09:54 AM
lukytry
Jul 9, 2006 01:41 AM
