Evo 9 EDM 88840013
Old Apr 17, 2021 | 07:20 AM
bsh's Avatar
bsh
Evo 9 EDM 88840013
Hi!
I will try to tune this almost stock Evo 9, but it seems like I cant find either boost limit or boost duty cycle table (greyed out). What to do? Can I use another rom and copy the immobilizer to it?
Thanks
Old Apr 29, 2021 | 04:56 AM
bsh's Avatar
bsh
Anyone?
Thanks
Old Apr 30, 2021 | 10:49 PM
Lancer_Evo_8's Avatar
You have to change your user Level
Old May 1, 2021 | 03:00 AM
Evo9_Dubai's Avatar
Just flash 88591715 instead.
I have an EDM car and 8859 is much more defined than 8884
Old May 2, 2021 | 10:09 AM
bsh's Avatar
bsh
Thanks but user level was already Developer...
Old May 2, 2021 | 10:12 AM
bsh's Avatar
bsh
Thanks for the answer. Do I just copy the immobilizer code and just flash the new rom with it?
Old May 10, 2021 | 03:40 PM
Evo9_Dubai's Avatar
Yes. You can also disable the immobilizer.
You might get a check engine because of the fuel pressure sensor but that never bothered me. It comes and it goes.
But the rom is well defined and easy to tune on compared to 8884
Old Jun 11, 2021 | 12:16 PM
bsh's Avatar
bsh
Hi, it seems like the 88591715 are speed density. Believe the 88590715 are maf. Tried to flash it, but did got this message: "[20:18:51.888] no response to any known code
[20:18:51.888] interface close
Is it because it is a .bin file, not .hex file?
What is the difference of bin and hex ending? Can I just rename the bin to hex?
Thanks
Old Jun 12, 2021 | 01:39 PM
Evo9_Dubai's Avatar
My apologies. I have been running SD for 12 years now, I forgot MAF even exists
No it isn't because it's a bin file. I can flash both .bin and .hex
You can flash your other rom without issue?
You can log properly?
Stupid question but do you have the write cable plugged in?
Old Jun 13, 2021 | 05:38 AM
bsh's Avatar
bsh
Ah i see I didnt try flash another this time, but was able to do it earlier.
I didnt try to log, but I could read DTC via Evoscan.
I forgot connecting battery charger when I tried to flash, and it coud be the culprit. Will try later.
Thanks
Old Jun 13, 2021 | 10:05 AM
Evo9_Dubai's Avatar
If the battery is low, then it will definitely not write
I have also made the mistake a few times of not plugging the write cable, specially when you get used to tuning with the EvoX.
Old Jun 14, 2021 | 12:43 PM
bsh's Avatar
bsh
It flashed with battery charger connected and it started with the new file. Must finish an Audi with flexfuel I have on the dyno and then will try to tune this one. Thanks
Old Jun 23, 2021 | 12:08 AM
bsh's Avatar
bsh
Got the car running with the 8859, but have issues with idle. Car stalls after deceleration... Found that other also have some issues with idle and it might be because that this is an EDM car. Have tried for several hours to get the car not stalling, but with no luck. Is there another rom that might work with this ecu, or does anyone have a definition file for the stock 88840013 rom that have load fuel cut defined so boost can be raised before it cuts fuel?
Thanks
Old Jun 23, 2021 | 11:51 PM
Evo9_Dubai's Avatar
Can you send me both your 8884 and 8859?
I am not sure why you are having issues on decel or idle. I have been running 8859 for 10 years now on my edm never had issues.
There aren't major differences between both cars except the fuel temp sensor and MAP sensor. Your stalling and idle issues might be tune related.
Lancer_Evo_8
Feb 13, 2021 10:36 AM
nightwalker
Apr 16, 2012 07:10 AM
Cruza
Apr 2, 2010 02:00 AM
evohemi
Apr 16, 2008 12:30 PM
racer135
Apr 8, 2008 10:27 AM
