EVO IX Injector Scaling
Originally Posted by jcsbanks
Have a look on the Evo 9 forum on openecu.org
http://forums.openecu.org/viewtopic.php?t=276
Originally Posted by colby
what ROM are you loading, and what field are you editing to cause a crash? What ROM XMLID is the file?
How do I find the XMLID? I've loaded my stock 06 MR rom in .hex format. The Internal ID is 88590013 and the Memory Model is SH7055. I don't know if that helps. It crashes when I try to change the Injector size scaling. By default the value is "<.." doesn't seem like its even a valid numerical value?
Originally Posted by 240Z TwinTurbo
What you have described is the reason why I started this post. The Evo IX map I have shows "<.." for the injector scaling. However, when I downloaded an EVO VIII map it shows the injector size.
Have you tried changing the value though? When I do that it crashes the program. Does that happen to you?
