log boost with JDM MAP sensor (updated instructions)
Old Sep 18, 2010 | 11:51 AM
  #766
sivs's Avatar
just did this today worked perfect!!!!!!
Old Sep 21, 2010 | 04:36 AM
  #767
Benja's Avatar
Originally Posted by evo_gerard
would really like to log boost on my 90550001. does anyone have a patch for this?
This is what I used successfully.
ROM Mods for JDM Evo 7 ROM 90550001
First is to add some definitions to your ECUFlash ROM XML definition file found in:
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Open the 90550001.xml file with the text/XML editor of your choice. Scroll down to the bottom of the file. Add the following lines just before the </rom> tag (copy everything *between* the ----):
<table name="MAP Test 1: Mid VE Max Voltage" category="MAPSensor" address="2046" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 1: Mid VE Min Voltage" category="MAPSensor" address="2044" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 2: Low VE Max Voltage" category="MAPSensor" address="204a" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 3: High VE Min Voltage" category="MAPSensor" address="204e" type="1D" level="1" scaling="Volts16"/>
After modifying and saving the ROM xml file, launch ECUFlash, open your ROM, and find the new entries. Note that they have their own category. It may be necessary to set ECUFlash to "Developer" mode in the ECUFlash options (and relaunch ECUFlash) to be able to see the tables. Here is what needs to be changed in ECUFlash:
MAP Test 1: Mid VE High Voltage Test -- Change from 4.61 volts to 4.90 volts.
MAP Test 1: Mid VE Low Voltage Test -- Change from 0.10 volts to 0.06 volts.
MAP Test 3: High VE Voltage Test -- Change from 1.80 volts to 0.51 volts.
In ECUFlash, find the "Periphery2 (FCA) Bits" table. Change bit.9 from 1 to 0. Use the "minus" key on the keyboard. This disables the P0401 (EGR) test.
After flashing that code, I swapped the factory Mitsu sensor out and replaced it with an Omni 4-bar.
Logs perfectly in Evoscan
Old Sep 21, 2010 | 09:46 PM
  #768
23r0k001's Avatar
updated rom from 88590015 to 88590715...can I assume these settings would remain the same? also what about the issue in post #757; no one has this issue?
Old Oct 2, 2010 | 08:57 AM
  #769
mchristian's Avatar
Anyone know if MrFred is still selling the 3 bar MAP sensors? I've pm'd and emailed him and have not gotten a response...I read he had them cheaper than mitsubishiparts.net.
This sensor was going for $125 "shipped" but they kept increasing the price.
Now it's over $50 more??? Ridiculous...
$152.02 + $18.24 for shipping...on something that's small & weights a few onces!
Old Oct 3, 2010 | 12:52 AM
  #770
Benja's Avatar
Why not the Omni 4-bar? Mitsu 3-bar will only read to ~29.5psi anyhow.
I got my 4bar for ~$100USD.
Old Oct 3, 2010 | 09:58 AM
  #771
mchristian's Avatar
Looking into this now, thanks for the suggestion...better & cheaper!!!
maperformance.com has them for $109 with free shipping and I found mrfred's Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9 thread with all the instructions.
Old Oct 3, 2010 | 12:10 PM
  #772
Jack_of_Trades's Avatar
Some people will never go over 30psi on their setups (and I believe the JDM Map sesnor actually reads to like 32psi in actuality). The higher boost the sensor reads, the LESS resolution the sensor has so its not always a wise choise to go with a larger map sensor if its never needed.
Old Oct 3, 2010 | 06:37 PM
  #773
HornstarBU's Avatar
Originally Posted by evodziobak
What about ROM 96530706 from Tephra v7 ??? Did any one get the JDM 3bar to work on that rom? I would really like to switch to v7 but I'm not sure about logging boost with the 3bar map sensor with that ROM.
Sorry to drag up this post, but I have this question as well. I saw some people saying "it just works, no changes necessary to log boost" and I don't know what to believe, or what is needed or if it's possible.
Old Oct 10, 2010 | 02:14 PM
  #774
Evo-B's Avatar
So I did the install a couple of weeks ago.... Ever since then I had been getting weird DTC's. Every thing from the MAP to the fuel injectors... So it turns out switching the values for ECU Periphery #2 and #4 will do this. The car ran fine and boost logged perfect. So I switched the values and no more codes are being thrown.
So my real question is what do these values do?
Old Oct 12, 2010 | 12:23 PM
  #775
23r0k001's Avatar
Anyway we can get an updated guide for use with evo9 rom 88590715
Old Nov 1, 2010 | 11:55 AM
  #776
BarryC's Avatar
well guys need a llittle help here
I have a JCBanks 90550001 SD rom that works perfect with the stock evo 7
map sensor but this sensor is only 1.5 bar
used the settings above and installed the evo 9 JDM 3 bar sensor,
I am able to log boost with the 3 bar sensor and it looks accurate
but cannot get the car run with the 3 bar and SD patch
anybody got this Rom to run with the 3 bar???
Old Nov 1, 2010 | 12:06 PM
  #777
burgers22's Avatar
Hi Barry, I had my VII running with an Omni 4 Bar. Which bit is giving you trouble? The changes to the MAP settings are fairly well documented, getting the MAP sensor VE settings should also be be fine as John set the ROM to run with that MAP sensor. I can't say the slow speed running was as smooth as the MAF, but on boost it was pretty good.
Old Nov 6, 2010 | 08:16 PM
  #778
infini_IV's Avatar
So is anyone aware of what is required for this mod on a JDM evo 7 using 90550001. im interested in logging boost only not interested in controlling boost, the above tables im not sure are correct for JDM considering mine has no EGR
Old Dec 4, 2010 | 05:16 AM
  #779
MercenaryX2's Avatar
I've been searching around for the 96530006 definitions for this and can't find it anywhere. Could someone post them up if they're available?
Old Dec 4, 2010 | 04:11 PM
  #780
HornstarBU's Avatar
If you're talking about the MAP sensor VE and stuff like that, you don't need to make any changes to the 9653 rom. It's from a car version, like European or something, that doesn't have a MAP sensor, and it doesn't use it to make any calculations. So, basically, put whatever MAP sensor in that you want with the 9653 ROM, and the only specifics you need are what you'll put in to EvoScan to scale the data properly.
