log boost with JDM MAP sensor (updated instructions)
Old Mar 6, 2009 | 05:59 PM
  #616
raasfaas's Avatar
Originally Posted by wreckleford
If your car is JDM the periphery bits will likely be different. The EGR may be non existent. Are you sure you are using 88590015?
No my car is USDM...LHD
Can someone point me to where I can find these periphery bits tables...currently I left the value in periphery2 stock (EGR test enable) and I got a cel (haven't had a chance to read the code but I'm sure its EGR related) I thought that issue was sorted out..
I'm going to try and disable it the old way (EDDF in periphery2) but I guess the new way like appauldd says totally removes it.
Old Mar 6, 2009 | 06:44 PM
  #617
wreckleford's Avatar
Sorry, about the JDM/USDM. The two different ways are doing the same thing - modifying the same code. Just one way is represented in binary code and the other is in hex code.
Old Mar 6, 2009 | 07:02 PM
  #618
raasfaas's Avatar
No prob...thanks wreckleford I'm going to go try that right now...
Old Mar 8, 2009 | 09:58 AM
  #619
eitan's Avatar
Here are the ROM locations for 96420011. Follow the instructions for 96420007/96420008.
<table name="MAP Test 1: Mid VE Max Voltage" category="MAPSensor" address="2048" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 1: Mid VE Min Voltage" category="MAPSensor" address="2046" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 2: Low VE Max Voltage" category="MAPSensor" address="204C" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 3: High VE Min Voltage" category="MAPSensor" address="2050" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 4: Max Minus Min" category="MAPSensor" address="2054" type="1D" level="1" scaling="Volts16"/>
<table name="EGR MAP Check 1" category="MAPSensor" address="4EEC" type="2D" level="1" scaling="uint8">
<table name="RPM" address="6d84" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="EGR MAP Check 2" category="MAPSensor" address="4EFC" type="2D" level="1" scaling="uint8">
</table>
<table name="MAP Scaling for Baro" category="MAPSensor" address="12059" type="1D" level="1" scaling="uint8"/>
<table name="EGR Pressure Diff" category="MAPSensor" address="1F62" type="1D" level="1" scaling="Volts16"/>
<table name="ECU Periphery2" category="ECUPeriphery" address="fca" type="1D" level="1" scaling="Hex16"/>
Old Mar 9, 2009 | 07:40 AM
  #620
mrfred's Avatar
Thanks. I'll add it to the first post if one of the admins raises the size limit on my first post to more than 20,000 characters.
Old Mar 12, 2009 | 10:33 AM
  #621
ExViTermini's Avatar
Just getting ready to setup and try out my 3.5 bar, when I noticed that for the 0014/0015 roms there is no Map test 4 and no "map scaling for baro" items in the code, is that something that was missed or something that doesn't exist for those roms? Thanks!
Old Mar 12, 2009 | 05:46 PM
  #622
mrfred's Avatar
Doesn't exist.
Old Mar 12, 2009 | 10:51 PM
  #623
daisaw1219's Avatar
3 bar is 43psi....Does this mean this sensor can log up to 43psi and control boost up to 43 psi?
Old Mar 13, 2009 | 12:04 AM
  #624
GST Motorsports's Avatar
Take out 1 bar for atmospheric.
However I have logged up to 33psi with it.
Old Mar 13, 2009 | 09:12 AM
  #625
Originally Posted by mrfred
Doesn't exist.
awesome, thank you!
Tryed it out yesterday, using RoadSpike's values, everything worked perfectly, so far no cel's or anything.
Only thing I noticed is that the idle is a bit higher, so I assume its trying to use EGR at idle maybe or something is awry. Any ideas? What exactly do the lookup tables do/control?
Old Mar 13, 2009 | 10:13 AM
  #626
leecavturbo's Avatar
Originally Posted by leecavturbo
anyone know how i can retro fit a ix sensor to a viii that
doesn't have a sensor at all! so that i can log boost?
Old Mar 15, 2009 | 10:33 AM
  #627
Just wire it in...
Old Mar 18, 2009 | 10:10 AM
  #628
What do the map/egr tables actually control? My idle has been a bit higher since I did the conversion, and I'm trying to figure out why..
The EGR should not be active at idle, so I'm not sure why its different.
Also, those that have disabled EGR, have you seen a noticeable difference in fuel mileage?
Old Mar 19, 2009 | 10:13 AM
  #629
In the words of Johnny 5, "Input! Need more input!".
Old Mar 19, 2009 | 11:42 AM
  #630
fostytou's Avatar
EvoM Community Team
I haven't disabled the EGR, so I can't comment on that. I'm running fine with it running.
The MAP/EGR tables are mostly just for an internal ECU comparison. When the egr starts to do it's work these are a lookup at the MAP to see if vacuum is dropping as expected, which tells the ECU if the EGR is working or not.
Have you checked for vaccuum or boost leaks? That could cause a change in idle if you didn't seat the sensor properly or forgot to plug a line back in.
