log boost with JDM MAP sensor (updated instructions)
Old Aug 7, 2009 | 01:22 PM
  #676
D-VO's Avatar
Thanks a lot! Logs and guages match 99.99%.
Old Aug 7, 2009 | 05:56 PM
  #677
dsevo's Avatar
I have have an 03 evo 8 with rom 015 and I followed the instructions in post #1. When I log boost it is just reading 37.xx psi all the time without ever changing. I can't figure out what I did wrong. BTW, I am using an Omni 4 bar map sensor.
Old Aug 12, 2009 | 12:27 PM
  #678
D-VO's Avatar
I'm not sure if you've had your question answered yet, but I found the answer here: https://www.evolutionm.net/forums/ec...ml#post7387662. It seems you may have an older version of the sensor that needs the pins switched.
Old Aug 12, 2009 | 12:29 PM
  #679
D-VO's Avatar
Please help! After installing the omni 4 bar and implementing the proper changes found here and at the omnipower 4 bar settings thread, I have found that I'm getting a bad lean condition after boosting then adjusting the throttle back slightly, but still boosting. I loose power, it stumbles for a second, then the afr goes back to normal, all while having the throttle in the previous adjusted position. Can anyone help?
Old Aug 17, 2009 | 03:53 AM
  #680
Guille278's Avatar
Unhappy
Question to Mr Fred. I have read this entire post.
My respect for all his knowledge and dedication.
I Have an JDM Evo VI. I understand any stock Evo VI does not have a MAP or MDP sensor.
Can I install a 3 bar MAP and connect on a specific ECU connector? and boost log?
Case ID: MD360216
Internal ID: 22580006
I hope you can help me.
Thanks.
Old Aug 17, 2009 | 06:46 AM
  #681
cij911's Avatar
I have a brand new in box JDM Evo 9 MAP sensor fo sale if anyone wants / needs it...
Old Aug 17, 2009 | 06:54 AM
  #682
mrfred's Avatar
It looks like its possible. ECU pin #73 on your ECU should be a 0-5 V ADC input. You'll also need to splice into 5 V power and signal ground from the wiring harness. I'd need to disassemble your ROM to determine the RAM address that receives the signal. It would probably take me 5 minutes, so PM me to trade email addresses.
File Type: pdf
Old Aug 17, 2009 | 11:13 AM
  #683
golruss's Avatar
Mr Fred could you please clear your in box.
Old Aug 17, 2009 | 02:06 PM
  #684
Guille278's Avatar
This is the rom [ATTACH] 139072 [/ATTACH]
File Type: zip
Old Aug 23, 2009 | 10:49 AM
  #685
golruss's Avatar
Hi, I am using the 96530006 rom with SD patch and the 3bar evo x map sensor but when logging using evoscanver 2.6 it reads half of what my AEM boost guage is reading at idle. Anyone knows why?
Old Aug 24, 2009 | 01:04 PM
  #686
xmaciek82x's Avatar
I'm wondering if someone can help me out with my issue. I'm a total noob to ecoflash so far so I'm taking baby steps.
When I'm adding the MAP Scaling like instructed for ROM 88590015:
0.51
0.90
1.29
1.68 i get 1.69
2.07 i get 2.08
2.46 i get 2.45
2.85 i get 2.84
3.24
3.63
Even though I type in the value 1.68 it becomes 1.69
Old Aug 24, 2009 | 07:56 PM
  #687
Guille278's Avatar
Verifies this:
inHg NO= Psi
inHg (inches of Mercury) is typically used for vacuum
inHg (pulgadas de mercurio)
P (psi) = 0,491130 * P (inHg)
P(inHg) = 2,03602 * P (psi)
Old Aug 24, 2009 | 08:13 PM
  #688
Guille278's Avatar
0.51
0.90
1.29
1.68 i get 1.69
2.07 i get 2.08
2.46 i get 2.45
2.85 i get 2.84
3.24
3.63
Try Read this:
https://www.evolutionm.net/forums/ec...ctions-35.html
Old Aug 25, 2009 | 07:07 AM
  #689
xmaciek82x's Avatar
Originally Posted by Guille278
Thanks, so I guess I'm good
Old Aug 25, 2009 | 08:03 AM
  #690
golruss's Avatar
Verifies this:
inHg NO= Psi
Thanks man, I am traveling now so when I get back in a week I will check it.
