Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Mar 25, 2017 | 09:00 AM
  #481
Biggiesacks's Avatar
Originally Posted by UShouldLetMeGo
Ah yeah I downloaded Phenoms updated xml for v7 and replaced it with the other v7 I had and it worked. Thanks!
Since mine was tuned in the past and I did not have to modify anything in the xml all my tables should remain what it was from my cars ecu? Because the xml is just telling where to pull the tables and creation of tables essentially correct? Sorry when I learn I like to know dumb details about "how" and "why" things do what they do lol. I just want to know because I know they tuned for the Evo 9 turbo, cams, injectors, and exhaust previously.
That's correct. The XML is just giving the location and labels of the data. The actual information populated in those tables is from the ECU.
Old Mar 25, 2017 | 05:46 PM
  #482
Jp7's Avatar
Jp7
modifying bits and bytes in an ECU is actually alot like playing 8 bit nintendo back in the 1990s when game "genie came" out.
The game genie codes had hexidecimal values and locations.
No difference between that and fuel injection pulsewidth values, and ignition advance... lol
just like making super mario jump higher, or have infinite lives.
Old May 13, 2017 | 02:14 PM
  #483
city's Avatar
Question
help when i try to add this patch to my 9694001 xml file i get an error message and nothing works in ecuflash. heres a link to my problem i posted in another thread:
https://www.evolutionm.net/forums/ec...iting-xml.html
Old May 14, 2017 | 12:31 PM
  #484
mufasa39's Avatar
Whats with all the wrx and subaru stuff? never seen that for a EVO, This is not for a suby. You have a HTML editor,when you copy and paste?
Old May 14, 2017 | 01:06 PM
  #485
city's Avatar
I got the latest version of ecuflash v1.44.4799 from the tactrix website, so i guess thats why theres subaru stuff because the tractrix openport 2.0 can work with subarus too. i used note pad to edit the xml file. i didn't use a HTML editor.
Old May 14, 2017 | 01:26 PM
  #486
kaj's Avatar
kaj
Note Pad FTW. I've never been able to edit any other way, but it's been a few years since I've had to.
Old May 25, 2017 | 10:24 AM
  #487
city's Avatar
i've tried everything removing ecuflash and reinstalling it, i still can't get it to work. i am using windows 10 OS 64bit, i will try on my friends computer running windows 7 OS 32bit and see if it works.
Old Jul 8, 2017 | 01:50 PM
  #488
jsmcpn's Avatar
I wish I would have revisited this thread before going in for test! I had the original patch settings and failed because of the 3 monitors that shouldn't be enabled on an Evo.
Here's stock vs what works for me:
The "Part 1" value was put back to stock (0x4019).
The "Availability" values are now identical to stock 88590015 ROM.
Pass/fail values were taken from the stock ROM, and then I changed EGR and Catalyst '1'
Old Jul 8, 2017 | 02:03 PM
  #489
kaj's Avatar
kaj
Same thing happened to me. I fixed it and the smog tech said, "I don't know how you fixed it so fast, but it's passing".
I think I had issues because I had the rear o2 patch and it's settings were conflicting. All I now is I gave up, put the cat on and let it pass normally.
I never got the car to pass by only changing settings in these menus. I wish I could.
Old Jul 8, 2017 | 02:18 PM
  #490
jsmcpn's Avatar
Unfortunately I couldn't finish the updated patch before the testing stations shut down for the weekend. I'm out of town next week so I'll have to wait to re-test until next Saturday.
Last time I went, this ROM was not a problem with all the Availables set to 1, so their system must have gotten an upgrade. This time it was detecting that the Air Injection, Heated Catalyst and A/C Refrigerant monitors were "Available" even though they shouldn't be on an Evo! Air Injection is a diesel-specific OBDII monitor I presume.
Old Jul 8, 2017 | 02:24 PM
  #491
kaj's Avatar
kaj
All smog shops detect this. Odd they didn't catch it your first time.
Old Jul 8, 2017 | 02:50 PM
  #492
jsmcpn's Avatar
Does Cali actually dyno test Evos or just do the 2-speed idle sniff?
CO would normally dyno test a vehicle of this age, but the station manager told me they exempt the Evo because even stock they're too scary/difficult for general staff - clutch too grabby, etc.
Old Jul 8, 2017 | 03:54 PM
  #493
kaj's Avatar
kaj
visual and OBD-II scan. There are probably a few shops that are still doing the sniffer, but not to my knowledge. Those are RPM test only; none of them run AWD dynos.
Old Jul 10, 2017 | 07:16 PM
  #494
pk303's Avatar
I haven't had much free time lately but promised I would post in this thread for future reference of Evo 9 owners in Colorado. Normally Colorado will run cars on an AWD dyno but they will give you the option to have them scan your OBD system because the factory rims are "low profile" and can be damaged on the rollers.
I am running 88590715 Tephra V7 rom. I never had an issue with them passing my car with all of the settings on "forced pass". This latest go around I failed and was handed a report saying there was an issue with the obd systems being "not supported".
I started a this thread: https://www.evolutionm.net/forums/ec...supported.html
The resolution was changing the "Non-continuous monitor availability patch part 1" from forced pass (e000) to stock settings (4019). Double checking on my generic OBDII scanner, this produced the correct items reading as supported and the items being not relevant to the car reading as not supported.
It was also suggested that I change all of the items on the monitor pass/fail table to match the items on the monitor available/not available table. When I did this my scanner would come up with conflicting info that I was worried about the emission center catching. Example would be: heated cat would read not supported, not available and not complete with the two tables matching. (I was thinking it would be odd if a not available item read not complete.)
When I would change the pass/fail table to pass (1) for everything that same example for heated cat would read: not supported, not available and complete or n/a on my scanner. (It made more sense if it read n/a since the heated cat is indeed not applicable.)
When I compared the readings I would get for supported and not supported items on my wife's stock car, those settings matched exactly.
Attached is a screen shot of my settings that I passed with since its kind of confusing to describe.
Attached Thumbnails Patch: Force OBD Inspection Pass (acamus, mrfred)-emission-pass.png
Old Sep 6, 2017 | 12:56 AM
  #495
EV09AWD's Avatar
5 Year Member
Any updates did you pass with your new settings?
And also how do you get rid of the Air Injection available?
