TephraMod V7
Old Apr 21, 2011 | 07:24 PM
  #2296
Benja's Avatar
Bout ~10.7 on a perfect run.
Basic rule is one tenth gained on 60ft is worth two in the traps.
Old Apr 21, 2011 | 07:26 PM
  #2297
Benja's Avatar
Dave, have you had anyone experiencing any issues with the WGDC being different to whats logged?
The values in the table do work, as I lowered them ~20units and it dropped boost by 6psi.
But they aren't matching up to the logged values creating a little headaches when trying to tune boost.
Using the latest XML too.
Attached a 3rd gear pull.
Old Apr 21, 2011 | 08:09 PM
  #2298
W2J's Avatar
W2J
Originally Posted by burgers22
I would suggest renaming the TephraMOD-90550701-v7.xml from xml to a txt file, that way you can still use that xml if needed. Please feed back on your track work and how things went.
when I use this def it changes my injector scaling to a higher value, is this normal?
Old Apr 22, 2011 | 12:30 AM
  #2299
HyperDisorder's Avatar
Donation sent for 96260009. Thanks for your time and effort Tephra
Old Apr 22, 2011 | 05:16 AM
  #2300
HsamehH's Avatar
what about the max timing retard for 90550001 ? can it be up to 20 degree ?
Old Apr 22, 2011 | 12:35 PM
  #2301
criptballer's Avatar
so i'm the only one who's ever had issues logging with v7 tephra mod?????
Old Apr 22, 2011 | 01:47 PM
  #2302
Acree's Avatar
Originally Posted by Acree
From what I've read so far, it seems that 88591715 (Tephra v7 with SD) is already patched to use the Fuel Temperature input for the MAT.
Can someone tell me how to configure the rom so that I'm actually using the Fuel Temperature Sensor as my MAT sensor? I'm thinking it's already setup that way, but would like a confirmation.
-Acree
Quoting myself because I still can't find the answer in any thread I can find. Sorry for the dual post, but would like confirmation from someone who knows more about it than I.
-Acree
Old Apr 22, 2011 | 09:17 PM
  #2303
tephra's Avatar
whats the issue dude?
Old Apr 22, 2011 | 09:21 PM
  #2304
RoadSpike's Avatar
-Acree
In the programming section there is a small 1D table for setting the input for MAT.
Fuel temp sensor location is 0xE while maf IAT location is 0x3. Just change the numbers accordingly.
Old Apr 22, 2011 | 09:24 PM
  #2305
Benja's Avatar
Anyone have any boost control issues with V7 like I do above?
Old Apr 23, 2011 | 12:12 AM
  #2306
RoadSpike's Avatar
Whats your air temp reading?
There is a maf air temp WDC correction which adds up to 5% duty if the temp reaches 95F or higher. It also subtracts up to 10% if lower than 14F. Maybe this table isn't defined for you yet and it needs to be to get consistant WDC.
Old Apr 23, 2011 | 12:38 AM
  #2307
Benja's Avatar
Bingo, it was ~15*C maybe a touch lower last time I went logging.... good call.
I'm assuming I should ignore the correct that this table applies as it works seamlessly in the background, setup the WGDC for my desired targets in each gear and go from there?
Only prob is the table states it should pull -1.0 at 15*C, at 6k the WGDC should be 73.5, however its logged at 79.
Its 5.5% WGDC higher for every point throughout the pull exactly.
edit: Appears to be defined in 90550701, however its like the WGDC table or something is incorrectly defined.
Old Apr 23, 2011 | 12:42 AM
  #2308
Acree's Avatar
You are awesome. Thank you sir.
-Acree
Old Apr 23, 2011 | 12:57 AM
  #2309
RoadSpike's Avatar
That table will use the scaled value, what is logged, so i'd go by that. Maybe you can adjust the table based on how sensitive the turbo is to change. For my fp red i used a max correct of +2% and -2% for the extremes since I wanted very little change in WDC even in extreme weather.
Old Apr 23, 2011 | 01:27 AM
  #2310
Benja's Avatar
No dramas, stock 9.8 rear turbo, on stock dump and stock piping, so turbo takes a fair bit of %DC to get it to change. lol
