Where to connect WBO2 Sensor
Hello guys, I have a problem.
I'm going to self tune my X, and get to know the car a little better. Reading tons of PDf, and forum notes. And finally deciding to tune it myself.
And I need a WBO2 meter, and decided on the innovate LC-1, and was thinking where do I connect it to??
Do I connect it to my laptop?, or do I connect it to the ECU. If I connect to my laptop, does it come with a USB to send the signal to the laptop?
And if I connect it to the ECU, which wire do I connect it to, and what value should I get the AFR reading from?
Most guides say I need a WBO2 sensor, and positioning it before the cat, and above the 9pm and 3pm marks so as not to damage the sensor.
Many thanks regards
P.S I don't plan to eye ball the gauges, I want to log RPM and AFR side by side.
I plan to log with evoscan,
Many thanks regards
You have to install an additional o2 sensor in the exhaust stream. Test pipes usually come with an extra bung welded in for the wideband o2 sensor making install much easier. I don't know about the innovate, but my AEM wideband has a serial data out that connects to my laptop.
I am using a LC-1 With the o2 in the 3' o clock position logging is pretty seamless with the new evoscan. If I were to do it again though I would go with aem, its less finicky with the ground wires.
i just installed my lc-1 and wired it into the ecu. fairly simple install, just took me a while to keep things pretty. i plugged the wideband into the cat for now until i upgrade my exaust. its all working great so far with the tactrix logger.
