Real 2-Step
Old Jun 27, 2016, 05:02 PM
soeuroithurts's Avatar
Real 2-Step
After searching a bit on the web i can't seem to find out if there is a way to cut ignition on the x through open source tuning. I want to enable true 2-step(not launch control) Anyone can share some insight on this?
Old Jun 28, 2016, 07:09 AM
tephra's Avatar
You want ignition cut instead of fuel cut?
Old Jun 28, 2016, 07:26 AM
Correct, as well as nls. I was trying to contact you for you mod.
Old Jun 29, 2016, 09:52 AM
Bump
Old Jul 6, 2016, 06:23 AM
jakgal04's Avatar
I was looking into this a while back but came to the conclusion that:
1: Can't be done on the stock ECU
2: Is far more harmful than fuel cut
I could be completely wrong, but thats what research led me to.
Old Jul 6, 2016, 07:40 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
IF tephra has launch maps for the X, you can severely retard timing in the areas of the map it hits, and add a bunch of fuel to make it more like real 2 step.
Tephra V2 has NLS (no lift to shift).
If you a true motorsports 2-step or antilag, you'll need an aftermarket ECU. The stock ECU does not have code for ignition cut.
Old Jul 6, 2016, 06:26 PM
That's what I thought. I guess I'll just try to retard the timing and add fuel and see if this works. If not, standalone time.
Old Jul 6, 2016, 08:14 PM
franzcars's Avatar
Actually I wrote a patch to do just that, created a spark cut 2 step and rev limiter, however I never released it to the public due to the disrespect and discouragement I received. However On my car I built 16psi in .4s and on a SST car we were able to build 8psi on the launch control where stock it would not build any. Here is a video of it in action on my personal car
soeuroithurts (Jul 6, 2016)
Old Jul 6, 2016, 08:26 PM
Dude, I actually saw your videos on youtube when i was looking around. I knew there had to be a way some how, I used to add the coding on s4s. But why would you receive disrespect and discouragement for trying to accomplish it? This is what I need and its bad ***.
Old Jul 6, 2016, 09:28 PM
franzcars's Avatar
It is a very debatable topic on if ignition or fuel cut is better for the motor. All of my friends who build high hp v8 cars only use spark cut, which is why I developed the patch. However everyone on the forums hates the idea of it, so I've never released it. I know the 2 step is not super safe on a stock motor due to the added stress of it on the components, but any spark cut like that isnt the safest
Old Jul 6, 2016, 09:41 PM
I always had spark cut on the previous car and I never had problems with it. So I'm not sure why people cry about it. If you don't like it don't use it. Simple as that. Other than that, good job on the patch.
Old Jul 7, 2016, 09:03 AM
franzcars's Avatar
I've been running it for over a year now with no issues, but if you ask the fourms my car will nuke itself...
Old Jul 7, 2016, 10:05 AM
That's awesome. I was completely unaware someone had come up with the code for that. Idk why people wouldn't want to use it. Works way better than fuel cut. And its arguably harder on the turbine wheel. But that's only with true ALS in my opinion where the system bypasses charge air into the exhaust manifold for really big bangs...lol. As long as you're not spiking 30psi on the spark cut, I think it's fine.
Old Jul 17, 2016, 09:59 AM
franzcars's Avatar
For those interested, we're doing some testing on other cars, so this patch might be released!
Kjarri (Jul 23, 2016)
Old Jul 30, 2016, 10:53 PM
franzcars's Avatar
Bit of an update, tested this on a MR with a upgraded turbo, we were able to build 3-4 psi on the launch control with no changed to timing or mivec, and he was able to pick up .3s on his 60ft, again with no changes except for this 2 step, so there is progress!
Murch
68
Sep 8, 2014 04:29 AM
EVOONYOASS
Jan 12, 2006 11:05 PM
eazyevo
Sep 24, 2004 11:44 AM
BaLListic_EVO
May 15, 2004 10:07 PM
dazinith
19
May 7, 2004 01:50 PM
Quick Reply: Real 2-Step
