obd force patch for ROM 59590004
Hey everyone,
I posted this in the general section but figured I would put it here in case anyone needed it. This is CONFIRMED to work.
OBD patch ROM 59590004
Enjoy!
Code:
<table name="Non-Continuous Monitor Completion Patch 1 0xA0BD->0x6000" address="91224" category="OBD Inspection" type="1D" level="2" scaling="Hex16"/> <table name="Non-Continuous Monitor Completion Patch 2 0x87C2->0x7000" address="91226" category="OBD Inspection" type="1D" level="2" scaling="Hex16"/> <table name="Monitor Available(1)/Not Available(0) - Read Only, Do NOT Change" address="01950" category="OBD Inspection" type="2D" level="2" scaling="blobbits"> <table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" elements="8"> <data>EGR system</data> <data>Oxygen heater sensor</data> <data>Oxygen sensor</data> <data>A/C system refrigerant</data> <data>Secondary air system</data> <data>Evaporative system</data> <data>Heated catalyst</data> <data>Catalyst</data> </table> </table> <table name="Monitor Passed(1)/Failed(0) - Read Only, Do NOT Change" address="91225" category="OBD Inspection" type="2D" level="2" scaling="blobbits"> <table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" elements="8"> <data>EGR system</data> <data>Oxygen heater sensor</data> <data>Oxygen sensor</data> <data>A/C system refrigerant</data> <data>Secondary air system</data> <data>Evaporative system</data> <data>Heated catalyst</data> <data>Catalyst</data> </table> </table>
Hakmeister
16
Oct 18, 2011 07:15 PM
