Dyno flash+New larger FP RED=HP!!!
Old May 14, 2009 | 04:42 PM
  #91
silver9mr's Avatar
thanks for the info guys ill be applying it hopefully tomorrow when i do my test this way
Old May 14, 2009 | 06:01 PM
  #92
MR Turco's Avatar
Silver9mr i just did a compression test yesterday 140-150-150-150. Let me know if you need a hand.
Old May 14, 2009 | 06:19 PM
  #93
gsr0801's Avatar
COngrats man, AL got me 510whp with the old Red at 30psi on 93 oct and meth. 415 on just pump at 24psi is really good.
Old May 14, 2009 | 06:46 PM
  #94
BlueDemon's Avatar
Correction.....24 psi.
Old May 14, 2009 | 09:53 PM
  #95
High_PSI's Avatar
Is this a NEW FP Red or the same FP Red??
Old May 15, 2009 | 04:22 AM
  #96
silver9mr's Avatar
well its the same red as always but its got a new larger inlet housing
Old May 15, 2009 | 08:39 AM
  #97
drb's Avatar
drb
Here is a good thread on how to do a compression test:
https://www.evolutionm.net/forums/ev...-test-how.html
The compression numbers quoted in this thread are for an EVO VIII. The EVO IX compression numbers should be in the 135 to 145 psig range.
You will get higher compression numbers with the throttle body open as opposed to the way that you tested (TB closed).
Try a different compression test gauge, I have seen major variances between gauges.
Dan (drb)
Old May 15, 2009 | 09:10 AM
  #98
silver9mr's Avatar
Dan (drb)
thanks dan thats exactly what i was looking for
Old May 15, 2009 | 01:54 PM
  #99
silver9mr's Avatar
so i did my compression test and it seems fine it was 140,145,150,145 and then i did the test to my friends stock motor and it was exactly the same
Old May 15, 2009 | 01:55 PM
  #100
Wicked E's Avatar
Wipe your brow...
Old Jun 5, 2009 | 03:53 PM
  #101
SASD209's Avatar
Admin Alumni
This thread WAS full of a bunch of posts that were either not related to the OP or repetition of rumors, facts, and other garbage that has no bearing whatsoever on the topic. If you have an issue with a shop, make your own tread in the appropriate area. If you can't keep it on topic and respectful of our rules, DON'T post.
Old Aug 25, 2009 | 07:41 AM
  #102
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
To the OP any new news about your setup yet?
Old Aug 25, 2009 | 05:25 PM
  #103
EvoTamer's Avatar
haha long hecktic day that sounds just about right
Old Aug 25, 2009 | 05:26 PM
  #104
EvoTamer's Avatar
yeah bro i saw ur car there the other day when i was there, i was loooking at it like oh man he has all this crab in his car guages ets.. and then a stock turbo rough, then i went inside and george was explaining that you had an fp red and was talking about meth and some crazy numbers and i was laid to rest
Old Aug 25, 2009 | 06:56 PM
  #105
silver9mr's Avatar
well first off when did this get unlocked lol...
and i got my boost leak fixed wich was the TB seals then my A/F went crazy so i went a while then i got some tunning the other day during the 100degree day last week and got 361 on a mustang dyno with boost falling from 27 to 24 so i got some work to do still
