Dyno flash+New larger FP RED=HP!!!
lol i dont think ill mess up those step haha i hope not. pull coils,wires and plugs. ad a lil oil then hook up compression tester and crank motor and see compression. repeat for other 3 cylenders.. is that correct?
but yeah, you've got it brother!
is there any body out there that has done a compression test on an evo 9 recently, if so i would really like to know what you came out with im hearing from 2 reliable resources 2 differnt things, that 125 compression is bad for a motor and another saying that the mivec motor has a compression like that any ways. so if there is anybody out there that has more info that would be great
110-95-110-105 dry
135-115-135-140 with oil
Now you can see why I'm doing a complete re-build.
Honestly, take your numbers... add the oil and take your numbers again. If it bumps up, you know rings. If it stays, its most likely a head/valve issue. At that point, it would be a good idea to do a leak down test.
-E
seriously? wouldnt that flood the motor? the first compression test i did i did not touch the gas pedel at all. was i supposed to? and would that have made a difference for why i had low compression? or like i stated above does the evo 9 mivec motor have a low compression anyways?
nice.. yea i still need more time to get some more better passes i havent really shifted it hard yet cause i dont want to be part of the ''my 6 speed tranny let go club'' plus i believe my tune has a few issues to be worked out
Al tuned my built motor, T67 evo to 400whp. He said it wouldnt make more power. I went to another local tuned, it made 488 on pump. And i trapped 6 MPH higher then Als tune.
According to the service manual, you need to disconnect the crank shaft position sensor so ignition and fuel injection wont happen and then floor it while cranking the engine. Your compression should be 145 PSI with a max limit of +/- 14 PSI.
