cbrd and bbk FTW
Old Jun 6, 2009 | 04:41 PM
  #46
EvoBullet06's Avatar
wanna trade cars? lol
Old Jun 15, 2009 | 06:33 AM
  #47
shuttlegoose's Avatar
pic of intercooler???
Old Jun 15, 2009 | 01:07 PM
  #48
Buddlight's Avatar
https://www.evolutionm.net/forums/7102718-post1184.html
Does this work for you?
Old Jun 15, 2009 | 07:47 PM
  #49
evo4life400's Avatar
Originally Posted by Buddlight
how much is that bad boy?
Old Jun 15, 2009 | 08:45 PM
  #50
Buddlight's Avatar
Comparable to the BR Race Core or any other Garett 4" core. I have no prob telling you what I spent, however, since the price isn't on CBRD website I'll refrain from posting it. If you're really interested in it, your best bet is to call CBRD, leave a message for Chad letting him know that you're interested. He ma not call you back in the next two minutes, but he will call you back prior to him leaving, at least that was my experience along with many others.
Old Jun 16, 2009 | 07:40 AM
  #51
CBRD's Avatar
PM me, email (chad@cbrdspeedfactory.com) or call 717 751 2345 ext 101 (leave a message and ill get back to you within 24 hours!)
I like to talk to each potential client to make sure they are finding the right solution for their needs, not just buying a part!
cheers
cb
Old Jul 27, 2009 | 09:56 AM
  #52
Levar's Avatar
Veteran: Army
Originally Posted by atkins
chad and i will be going up there tom for a slight retune with the cbrd front mount and a aps twin vent bov.
Does a BOV really make that much of a difference? I know it's a newbie question but I was under the impression that an upgraded BOV is an upgraded BOV. If that is not the case and I currently run the Forge RS BOV, what would you fellahs recommend me upgrading to and why?
Originally Posted by scheides
Are you tuned with the stock load-based boost control or do you have a JDM map sensor w/ mrfred's psi-targed boost control setup?
Scheides, you and I have exchanged emails over the past week. Remember Levar the guy in Iraq? Well, I've never heard of this type of tuning as I'm currently ECU-tuned by KevinD. For the map sensor, I've strongly considered the GM MAF/translator set up. Can you shed more light on what you are talking about above and does my GM MAF plans suffice?
Old Jul 27, 2009 | 02:22 PM
  #53
scheides's Avatar
EvoM Moderator
Run a stock IX bov and crush it ever so slightly, it is the best one on the market and it holds boost just fine. Driveability with the forge sucks imho.
Skip the GM MAF-T, 100% useless on an evo. Keep the factory MAS/MAF in place. What I am referring to here is two hacks by mrfred. The first one uses a an evo X map sensor (3.3 bar) to log boost via the stock ecu, then, the second one uses that boost measurement as a target for your boost control tables. The stock setup refers to a target engine load, which is less ideal.
Old Jul 27, 2009 | 07:03 PM
  #54
atkins's Avatar
when we retuned we uped the bost to 27.5 psi and the evo 9 blow off valve has been said to leak over 25psi. if your blow off valve is leaking boost that means your turbo has to work harder to produce target boost. if the turbo is working harder to create less boost, thus not working as effeciant as possible. turbos that work harder then the have to means they are blowing hotter air which leads to knock, not allowing you to run as much timing or fuel = less power.
crushing a 9 is known to work, but i decided to go with the aps twin vent. i literaly have no drivability issues at all, it work just as good or better then the 9 bov without leaking.
jeff
Old Jul 27, 2009 | 11:13 PM
  #55
Levar's Avatar
Veteran: Army
Scheides, I'm in no way questioning your response whatsoever. Back in the day, I spoke to the English Racing crew when I was entertaining building around the stock IX turbo and they swore by the GM MAF-T set up adding (what I believe) roughly 15whp. I'm not too fond as the MAP crew has also recommended me getting the same set up for roughly $330 total. What are your thoughts on this? Also, could you send me a link to this Mr. Fred upgrade as I've never heard of it? Thanks.
when we retuned we uped the bost to 27.5 psi and the evo 9 blow off valve has been said to leak over 25psi. crushing a 9 is known to work, but i decided to go with the aps twin vent. i literaly have no drivability issues at all, it work just as good or better then the 9 bov without leaking.
"Has been said to leak" but has that been confirmed by anyone you know of? I'll look into both the stock IX and APS twin-vent BOVs. I'm glad that you fellahs taught me a thing or two as no detail should be overlooked.
Old Jul 27, 2009 | 11:46 PM
  #56
xRoguex's Avatar
The CBRD fmic - is the largest fmic you can install with zero cutting right?
I have yet to install my BR race - I am assuming it is just a hair bigger - and it says it does require some trimming.
Old Jul 28, 2009 | 04:35 AM
  #57
CBRD_Caleb's Avatar
The BR Race and our intercooler use the same exact core... the tanks, inlets/outlets, and brackets are the difference. Ours requires no crash beam trimming, and both the inlet and outlet are in the stock location, so any IC piping that fits in the stock location will work. Both are fantastic pieces.
Old Jul 28, 2009 | 07:04 AM
  #58
Drizzy Drake's Avatar
What's the price on the cbrd ic?
Old Jul 28, 2009 | 07:39 AM
  #59
xRoguex's Avatar
I thought yours was only 3.75
Old Jul 28, 2009 | 08:09 AM
  #60
CBRD_Caleb's Avatar
It's the "4 inch" core... which really measures like 3 7/8 inches (or something close). Again, it's the same core used on the Buschur Race IC.
