opinions please :)
Old Jul 31, 2009 | 10:07 PM
Justin VIII's Avatar
i figured i would do that, i thought the volume of air would be the same just the turbo would be working no where near as hard as it was...
Old Jul 31, 2009 | 10:20 PM
fuzzydoodle's Avatar
Well yeah, from my understanding, you had it tuned with a 9 turbo, and a plastic 8 DV?
Then replaced the valve, with a 9. If its running off the WG, then its tuned for 18?
But whatever its tuned for is what its tuned for, the bov should not matter, set the boost.
The hot weather will make it run like garbage too, or seem way slower, turbo's ( or really any car) -
cold air = good
hot air = bad.
Old Jul 31, 2009 | 10:27 PM
no its tuned for 25 pounds, so i just adjusted it for the same and ran it
Old Aug 1, 2009 | 02:23 PM
zeus1's Avatar
make sure you have no boost leaks, good plugs, car is mechanically sound, you have a wideband then just get a mellon tune. you will be VERY happy.
Old Aug 1, 2009 | 02:30 PM
binh's Avatar
retune wont be 400. they will cut you a break on a retune.
Old Aug 1, 2009 | 10:48 PM
true, ill see what they say monday
Old Aug 3, 2009 | 04:00 PM
K1tt3n5's Avatar
Updates?
Old Aug 3, 2009 | 04:40 PM
griffeyr's Avatar
yeah they should cut u a break on the tune
just curious, whats ur rev limiter set at since ur using the kelfords and stock valvetrain?
Old Aug 6, 2009 | 05:07 PM
ok..so ive herd NOTHING from TTR.....so im in a limbo, loggeds my car and it running funky, so i need a retune for sure. As of now im set to get tuned by Sean Ivey with my friend this upcoming thursday.
my rev limiter is set at 8k.. i think. ive never hit it. i always shift before 7600rpms.
*the kelford 272 cams are VERY aggressive, it lopes alot more than HKS 272, so it makes driving around in bumper to bumper extremely annoying*
on the plus side, it sounds rediculous
Old Aug 6, 2009 | 05:14 PM
evo8jdm's Avatar
did you get tuned on friday?
Old Aug 6, 2009 | 05:16 PM
evo8jdm's Avatar
Originally Posted by Justin VIII
Hey guys just got tuned by Mark at TTR (great guy, great tuner) but i think my car itself should have made more power
340.76whp 328.72ft/lb (Run Conditions: 101.55 F / 29.84in/Hg / Humidity 22%)
mods
Injen Intake
Injen UICP
Injen LICP
Evo 9 Turbo
FP 18psi wastegate
Kelford 272/272
ETS 3.5" front mount
Walbro 255
TTR MBC
PTE 780cc injectors
NGK BPR8ES
APR Headstuds
Helix cat-back
DC downpipe w/ catdelete
Stock plastic 8 valve
I would have thought my car would have made in the neighberhood of 360whp
nothing would please me more than to blame it on the plastic valve and the 101 degree tuning weather
what do you guys think
I seen your car it has an evo 8 turbo actually i was there whene the tuner checked out the turbo
Old Aug 6, 2009 | 05:17 PM
it was initialy tune thursday, i picked it up friday as it began to Downpore
Old Aug 6, 2009 | 05:18 PM
and no, its a nine turbo with an FP 18psi wastegate, the wastegate is the reason they thought it was a green. i have pictures of that turbo on and off the car
Old Aug 6, 2009 | 11:15 PM
evo8jdm's Avatar
well the car sounds great and hope your happy with the power that it put out.....
Old Aug 7, 2009 | 05:02 AM
griffeyr's Avatar
man ur crazy for not upgrading the valvetrain with those cams....i wouldnt go past 7k if it were me, just to be on the safe side
