Joshsevo GT4088 TS E85 numbers
hemorrhoid?
nope not this year. i think the stabbing/ shooting incident kinda ruined it.
The car wasn't reving very high. You under estimate the amount of gas volume it takes to spool a 40r. 33 psi isn't squat for that turbo.
Tobz is the pump maxed out or is it maxing out the injectors? If so have you considered the duel feed lines for it?
Whats cams are you running?
+1 for another post
I wasn't talking about gas. The 2.3L can't rev like the 2.0's. The more RPM's you can hold your peak the faster the car is going to run. I am sure the car pulls hard based on the dyno numbers, it just doesn't pull that hard for very long. Sure you can add more fuel and more PSI but it won't change how high the 2.3L can rev.
+1 for another post
+1 for another post
Moving on!! Josh, with all this new nasty power, would you say your evo is finally built, given a few tweaks to get the most out of the new set up?
What have you done to upgrade trans/clutch? Do you have any worries about holding this kind of power on your current set up?
Early on in the testing the car was only being reved to 7K. Tobz asked me how high can he rev it to, since it was my motor he was being polite and I said wrap that biotch out to 8500. See how good of a motor it really is. So if the results are showing them letting off early I would not worry to much cause the few times I do get on it I will wrap her out....trust me.
Jeff,
The car is fully built as is the tranny. Remember I broke reverse a long time ago and had to drive around with no reverse for like a month. You were at the big red rocks meet weren't you? The car would grind real bad in reverse.
Who cares, it's his car, his decision on parts, not yours
Sorry I am not excited, guess I don't see what everyone else sees, especially when you consider the costs. What ever happened to bang for your buck?
Jeff, he didn't mention the clutch but I know Josh has an upgraded TC and Tranny from Jack. Unless his front diff goes I doubt he will have any trouble putting it down.
Get the car back on the dyno and put up the numbers to shut me up
No I have not asked Harvey to tune my car. I have an allegiance to a shop and a tuner until I get burned. Which I was while I was at the other shop.
I do watch over my car. I never take it out cause I feel one you guys may vandalize my car. So I just take it certain places and that's it. I drive in the far right lane, just cruising every where. I never really get on it anymore for fear of getting caught for speeding and being sent back to jail.
im very suspect of the motor for sure and i really dislike the color red but i have to admit his evo does look pretty clean flows nice. once he gets the motor right its will be a nice peace for sure. Josh have your considered getting Voltrex Front bumper Cyber street. Looks extremely better with the cf splitter for sure. I think it would flow awsome with your exterior setup.
I don't get it, why does Josh have to prove anything to you? His car put down 530whp on his first real tune since it's been broken-in, and he's not even done with the build. You want to see a path to hi performance, what's your benchmark for a hi performance? And what experience do you have with building, tuning or driving built Evo's I'm really interested...
+1 for another post
+1 for another post
