857 AWHP on Straight Pump E85
So I took my EVO to the dyno on Saturday for some tweaks and to see just how far I can push E85 out of the pump without mixing any other gas in with it. The first pull at 35 to 37 psi, with the boost fluctating, It put down 760 with a safe 11.5 a/f ratio. I then turned it up to 39 to 41 psi and it ripped the rollers with 855 awhp with the a/f still in the 11's. I then went to pull out some more fuel and my lab top locked up! What the ****! I then said screw it, let's just turn up the boost and see what happens. It put down 857 awhp at 45 psi with the a/f's still in the 11's just before it blew off something and was boost leaking bad. With my time on the dyno up, and other cars scheduled to go on I decided to call it a day. After pulling the car off the dyno I noticed the rear tires were rubbing the fenders pretty damm bad. The outside edge of the tread was shaved and sticky as hell. I have no idea how much loss it was creating, but it sure as hell wasn't helping. I boost leak tested it once I got it back to the shop. The line running to the boost controler and blow off valve ripped open. After fixing it I took it on the highway to see how it's pulling. The boost hit about 44 psi and I think I gave myself whiplash in second gear. E85 is nuts! $2.09 a gallon for what looks to be 900 awhp at this boost level. Insane!
I'd like to thank www.apmracing.net once again for helping me convert the car over to E85 corn liquor.
The dyno had a broken rpm pick-up so I couldn't print out rpm or torque. It's hitting full boost just before 7,000 rpm and I was spinning the engine to 9,500 rpm.
855 awhp full run
855 awhp full run with the 45 psi 857 partial run overlayed
Specs listed below
2.0 4g63
Crower Rods
Arias Pistons
Kiggly valve springs & oil regulator
FRH intake manifold & ported head
FP 4r intake and "Big" Crane exhaust cam
Machine work by Class One Freeport, IL
1600 cc Bosch injectors
DV/DT fuel rail
Autronic SM2 Tuned by me (Yusuf Begic) of APM Racing www.apmracing.net
Aeromotive A1000 upgraded to new version (similar to old eliminator pump)
Kenny Bell 40 amp Boost-a-Pump
DV/DT T4 Divided header
DV/DT FMIC with 3" pipes & Q45 TB
Borg Warner S374 w/ 1.10 turbine housing
EVO 3 trans with Shep Trans REM treatment
APM Racing/Quartermaster Twin Disk
Mechanical labor and fabrication provided by APM
Tuned By me, Yusuf Begic, APM Tuner
855 awhp full run
Specs listed below
2.0 4g63
Crower Rods
Arias Pistons
DV/DT fuel rail
My car is an EVO 2 with an EVO 3 short ratio gear box. If I roll into it at 4,000 rpm yeah, it's laggy, but if I downshift the power is right there. Also recovery time between shifts at that boost level is like a 16g! I'm not kidding at all. It's all about keeping the rpm in the powerband and how you drive it. On a 2.0 built motor that spinns to 10,000 rpm it's not a problem at all.
