The Shop evo 8 fp red 93 octane tune by junior!
Old Sep 12, 2009 | 01:57 PM
  #61
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by FTS EVO
Nice numbers. I have heard bad things about shells 93, did you incounter any problems with it?
The numbers I put down were all done with Shell 93. I used to use any name brand gas but since going with bigger power on stock motor shell is the way to go plus there are 3 in my area and all have great price per gallon
Old Sep 12, 2009 | 03:46 PM
  #62
silver04evo8's Avatar
1 quick question guys, iam on a big budget. iam making 315 whp on dynojet now, iam thinking on converting to e85 . Can a stock 04 evo 8 turbo with e85 run or making power as with an evo with fp red with 93 pump gas.? thanks. i am desperate for power now. i might go all out and buy an red and tune with e85 , but affaid to blow up the engine.
Old Sep 12, 2009 | 05:40 PM
  #63
bambooi's Avatar
Yup there are people on the forums with e85 and running as quick as a red on PUMP gas. Look at the drag racing forum. You will need bigger injectors.
I have to agree. I had a set of 780 brand new never used and I sold them and got 1k's. Although Jimmy said I would have a problem with them in terms of my driveability. But the car starts up just fine I have to let it idle for about 60 secs or the car acts like it want to flood a little. But I mean you can only do but so much with stock ECU right. But getting the 1k's was only to ensure I had enough fuel for pump and possible race gas. But for you I think that 880's should be good you will need them when you change the IC.
I have FIC Bluemax 1250 CC on pump gas idles fine.
Old Sep 12, 2009 | 07:57 PM
  #64
evo4life400's Avatar
i hope i dont need new injectors when i get the new intercooler...i dont have enough money
Old Sep 12, 2009 | 11:20 PM
  #65
dipsetinallday's Avatar
deleted.
Old Sep 12, 2009 | 11:51 PM
  #66
Nevermind.
Old Sep 17, 2009 | 04:44 AM
  #67
SuperchargedGTZ's Avatar
Thats just what I heard, I never used shell gas, I dont even think there is one around me but was just kinda wondering thats why I asked, but im guessing that you have never had an issue with it.
All I use is shell as well. Since the last few times i have had my car tuned, we cranked the boost up to 25-26psi with no KNOCK what so ever. First tuner asked me what gas i was using, to said "shell", he said, keep using it.
Old Sep 19, 2009 | 05:36 AM
  #68
EriCS's Avatar
Originally Posted by DBallz
I'm wondering too?
I'm glad I forced you to go up there. And I think you will make the right choice for yourself. You have the fall and winter to figure out what you want to do. I still think that pump is for you and I'm sorry flame me if you will but the new HTA Green is for you
Seems to make a ton of torque! Just waiting for more data and hopefully I can make it happen sooner than next spring.
Old Sep 19, 2009 | 07:37 AM
  #69
DBallz's Avatar
Meh shoot for the spring don't rush into anything
Old Sep 19, 2009 | 08:13 AM
  #70
i cant wait until i can get my CBRD front mount intercooler....i need a few other things before that but when i saw that guy ATKINS gain like 30whp with just changing the intercooler...i wanted it. once i get the 80mm, fp intake, oil line, and the intercooler i am going back to The Shop....and its going to be cold out this time
Old Sep 20, 2009 | 12:01 AM
  #71
R/TErnie's Avatar
Your spool up sucks. I hit 300 lb-ft @ 3700rpms.
Old Sep 20, 2009 | 07:19 AM
  #72
IDRINKV8'S's Avatar
i get full spool at 4,100rpm step to that....but 300tq at 3,700 is great..but i get around 370 tq at 3,900 on a d.d low reading dyno...
Old Sep 20, 2009 | 09:11 AM
  #73
R/TErnie's Avatar
I hit 370 @ 3900 and I started the pull @ 3200. Mind you this is prior to mivec tuning.
I'm just pointing out that you guys don't understand how PID controllers or actuators work.
Not to mention you're using a 1.2 CF at sea level in late September... so dive give me "low reading"
Old Sep 20, 2009 | 09:17 AM
  #74
IDRINKV8'S's Avatar
are u on stock cams?next month i might add some porting,cams,and a retune...
Old Sep 20, 2009 | 09:44 AM
  #75
R/TErnie's Avatar
stock bumpsticks. I'm putting the magnus on this week and heading to the dyno this coming weekend to spend a few hours tuning the car. You'll get to see what a fully optimized MIVEC map does for spoolup/powerband.
