New Dyno Chart using Tephra V7; Any Feedback?
Old Dec 16, 2009 | 08:42 PM
Evo_Jay's Avatar
Also, maybe you can get the gas your using tested for octane rating?
Old Dec 16, 2009 | 08:54 PM
racer135's Avatar
Car has a 3" WORKS resonated test pipe. Maybe I should try other gas in the area. Are octane boosters any good? Do they really increase the octane rating?
Exhaust is:
Self Ported Exhaust Manifold
Ebay Titek V2 clone O2 Housing
Works 3" DP
Works 3" Resonated Test Pipe
Works 3" Cat Back with their 3" Exhale Muffler.
Intake is Works Drop In and I hacked the airbox lid (cut a hole on the side farther from the engine heat).
Old Dec 16, 2009 | 08:59 PM
Evo_Jay's Avatar
Exhaust is:
Works 3" DP
Umm octane boosted are always debated, but I did once read a SCC mag that did a "real" test using a lab to test it, and yes, the octane boosters DID raise the octane. Some more then others. The article is prob on the net somewhere.
You may wanna try an open element filter in a hacked box. Your having knock and cant raise timing in the high RPM right? Well the filter will help out the high RPM, and will make the car LESS knock prone in the high RPM.
Just make sure to reduce your duty cycle, since running a open filter will make it run a psi or two more boost at redline.
Old Dec 17, 2009 | 10:47 AM
racer135's Avatar
Does my timing look low for 93 considering boost and mods?
Old Dec 17, 2009 | 01:32 PM
project_skyline's Avatar
No, with 93 and holding what looks to be 21 psi at redline that seems pretty good.
I'd say have more power with boost, if you have enough injector.
Knock is minimal and looks about MBT for that fuel. Maybe add a point of two of fuel into it and see if that reduces knock.
Old Dec 17, 2009 | 03:41 PM
racer135's Avatar
Its holding close to 22 psi by 7500. Redline is set at 8K. I am thinking about trying to add a little more WGDC at 6500 maybe 96% and run at 100% WGDC from 7000 to redline. If knock increase add a little more fuel or remove 1* if fuel does not help and check the chart again. Not sure if I should try a bigger spike on pump.
I have a set of PTE880 but have not install them yet. The stockers seems OK so far for pump. I am at about 95% IDC by redline.
Old Dec 21, 2009 | 06:04 PM
bsmart82's Avatar
Knock is being induced at 6250 by the 2 degree jump in timing which can be cured by smoothing the timing curve. I can get away with 15* up top on my stock turbo w/93 at 24psi so your timing is about where it needs to be. Power seems low but could simply be incorrect VDR settings. IMO if you know what to look for you will see a boost leak in a log IF you have before and after logs in very similar conditions by an increase in airflow at the same boost level. Either way, periodic boost leak tests are mandatory on turbo cars.
Old Dec 22, 2009 | 05:40 AM
racer135's Avatar
Thats what puzzles me. Timing and AFR are on track but power seems low. I went to a DynoJet with a very similar tune (before converting to V7) and got 347awhp so VDR settings seems to be OK.
The only thing I can think off now is a boost leak. But honestly I do not think I have one. Everything else looks good. 350 is not a low hp car but is not a high hp either. I was expecting close to 360~365 on a DJ.
Old Dec 22, 2009 | 09:51 PM
racer135's Avatar
Guess what. Tried to increase a little boost after 6000 rpms and got a lot knock (about 8 counts at some point). Airflow and boost profile basically stayed the same with the increased WGDC.
So I tried lowering the boost to 23 tapering to 22 in 3rd Gear and got an almost knock free run (1 count at the most in two back to back runs). Airflow was stilll the same with 1 psi less. Power increase a little also with 23 psi, not much maybe 3~4 hp at top. I have to superimpose the curves to compare the low end but its 2 AM. Maybe tomorrow.
I think the turbo does not like more than 23 psi up top because airflow was basically the same. Or the stock airbox is not letting more air in.
Flow in Lb/min was 41.5 and Airflow at about 2050 Hz bt 7500 rpms. Very interesting results. I am not sure if I should try 22 psi to see how much is the flow.
kaj
286
Nov 27, 2025 06:54 PM
scheides
Mar 9, 2010 01:32 PM
rogue
Evo X Dyno Results
12
Apr 14, 2009 07:00 AM
byt
17
Sep 27, 2006 09:29 PM
Levar
Apr 11, 2006 06:52 AM
