Buschur Racing's first 2.4 L engine build, results inside.
Old Jan 7, 2010 | 02:43 PM
David Buschur's Avatar
The initial results are finally in.
Here is the build:
2005 EVO8
BR 2.4 liter engine, 9.5:1 compression, billet crank, billet steel rods, forged pistons
Standard head with springs/retainers and just combustion chambers fitted to 2.4
Kelford 272 cams
MAP ported and coated exhaust manifold
FP RED
MAP ported intake manifold
BR 65 mm throttle body
BR 3" turbo back
BR Race FMIC
Stock ECU using Tephra 7
93 octane of some sort
BR manual boost controller
The car, I believe has some poor fuel in it as it is very knock prone and at the end of the dyno session today I dumped a few gallons of race gas in it to see what would happen to the knock counts, they dropped to zero. I am out of time today so Monday we will drain the fuel out and put in some fresh Shell 93 and put it back on the dyno.
The car was tuned, as you will see on the sheet, with a peak boost of 25.2 psi. The car makes 25.2 psi with the FP Red at 4000 rpm and also makes 444 ft lbs of torque at 4000 rpm. Power is excellent but with a better timing map in the car I am sure that even at this boost level the HP and Torque figures will both climb considerably.
I'm happy with the build, even at this level and even if there are no improvements from changing fuel and re-tuning.
Old Jan 7, 2010 | 02:46 PM
Gary@MellonRacing's Avatar
damm impresive, david buschur do u think this build has a 9.9 in it on race gas ?
Old Jan 7, 2010 | 02:50 PM
ROGERV's Avatar
Wow at only 25psi...Very Nice !!
Old Jan 7, 2010 | 02:55 PM
PeteyTurbo@KHC's Avatar
Force identical scales
Looks good
Old Jan 7, 2010 | 02:59 PM
E-SPEC INDUSTRIES's Avatar
In on the first page for this one!!!
Old Jan 7, 2010 | 03:04 PM
AWD Motorsports's Avatar
Very nice as expected!!!
Mike
Old Jan 7, 2010 | 03:05 PM
dsm25psi's Avatar
MAP intake and exhaust manifold???
Old Jan 7, 2010 | 03:06 PM
5LEEPERISAH23I's Avatar
Sweet!!!
Old Jan 7, 2010 | 03:22 PM
ch53avitech's Avatar
I'm guessing the MAP products were already on the customers car.
The spool rate is really impressive. I'd like to see a FP HTA86 or similar on in there. Someone is going to be a happy customer.
Old Jan 7, 2010 | 03:26 PM
MJ23FE's Avatar
Very nice results! Is it me or is torque falling hard as hell?
Also something I noticed, why not use ECU controlled boost?
-Jalal
Old Jan 7, 2010 | 03:49 PM
xRoguex's Avatar
The manifolds were already on it before I dropped it off.
We will see what more comes out from the better gas. Either way - this curve AS IS is good for what.. 11.2-11.4 or so.. if I can drive haha.
-Jalal
I asked David which he wanted to use - I had both his and the GM 3-port on hand.
Old Jan 7, 2010 | 03:50 PM
ChrisCarey's Avatar
Awesome results and for lack of a better phrase "mad props" to the Buschur team for getting Will back on the road so quickly!
Old Jan 7, 2010 | 04:24 PM
galant306m's Avatar
Nice!
Sorry dont post much here, this was posted on my natural forum haha. Will be following this now though and may stop in time to time, to ask a few questions. Finishing up a 2.4 dohc build in my galant atm.
Old Jan 7, 2010 | 04:25 PM
l2r99gst's Avatar
I forgot if you mentioned it somehwere, but what's the rod ratio on this motor?
Old Jan 7, 2010 | 04:29 PM
galant306m's Avatar
they are the same rods as the 4g63's just a different crank and larger pistons.
