Buschur Racing's first 2.4 L engine build, results inside.
Old Jan 7, 2010 | 04:40 PM
ChrisCarey's Avatar
It is indeed the same connecting rod, but the stroke is 100mm compared to 88mm in the 2.0l so the rod ratio changes from 1.70 in the 2.0l to 1.50 in the 2.4l platform...
Old Jan 7, 2010 | 04:44 PM
l2r99gst's Avatar
Yuck. OK, just wasn't sure if Dave wasn't using a longer rod or not.
Old Jan 7, 2010 | 04:46 PM
red03evo's Avatar
Good stuff David.
Congrats to the owner of the car.
Old Jan 7, 2010 | 04:50 PM
ChrisCarey's Avatar
He certainly could be sir, I'll let him chime in regarding this particular build. The information I provided was with the standard rod length and 100mm stroke...
Old Jan 7, 2010 | 04:55 PM
galant306m's Avatar
Ill stop talking! (non sarcastic remark)
I should explain more i guess when i talk, just know when i ordered new rods they were the same for the 63 and the 64 so by saying different crank the stroke would have to be different, if that makes more sense?
Old Jan 7, 2010 | 05:12 PM
xRoguex's Avatar
100 mm manley billet crank is used.
Old Jan 7, 2010 | 05:45 PM
norcalSRTrida's Avatar
Originally Posted by ch53avitech
I'm guessing the MAP products were already on the customers car.
The spool rate is really impressive. I'd like to see a FP HTA86 or similar on in there. Someone is going to be a happy customer.
coming from an SRT where we had a 2.4...no you dont. turbos of that size/nature need a higher rev than 7500 imo in order to be competitive.
i had a 6262 on my 2.4 srt. 7500 wasnt cuttin it.. 8k was much better. but w/ the Rod angle ratio the way it is, 8k is pushing it kinda...
strokers are good for these stock-frame style turbos. for these 70+ lb/min turbos id stick to a long rod 2.2 or 2.0 setup and take advantage of the power up top...
just my 2c coming from a background similar to this block/rev limit.
Old Jan 7, 2010 | 06:52 PM
David Buschur's Avatar
This build should be good for 9,000 rpm with the billet crank and parts chosen.
At this power level on our dyno the car will run 10.80-10.90's with a good driver and traction.
As I mentioned, I wasn't having the best of luck with the fuel. I did, I'd guess, 12 dyno runs in 3rd gear and then did one in 4th. The knock got worse as I guessed it would. I dumped some old race gas we had just to see if it would help at al and pulled one more time in 4th, knock counts dropped to nothing and this is the resulting sheet. I didn't pull it past 7500 because with the timing curve that was in it, the power was starting to fall.
Next week, Monday, we are going to drain both sides of the tank completely and then put some good fresh fuel in it from Shell here and throw it back on the dyno.
I'd really like to see what the car makes at 30 psi if I can get it there. Honestly, I don't think it's going to make it to 30 psi but we will see.
There are many reasons a car can't run high boost on pump gas and this car has some parts on it I don't normally use in our builds. Right now 25 psi was pushing it. Even at 25 psi if I can get the timing into a curve I like the power will climb and I am guessing substantially based on how low the timing is now.
BTW, there will be no reason for a build at this power level to go to the 9,000 rpm that it is expected to hold up to. I will rev it higher if the need arrises when it is tuned again.
scheides's Avatar
EvoM Moderator
Crazy that boost doesn't seem to build much sooner than on a 2.0L, but torque is through the roof! Badass power and torque for pump gas.
Old Jan 7, 2010 | 06:55 PM
kouzman's Avatar
congrats on the build guys!
cant wait to see this block on a big turbo and stand alone!
Old Jan 7, 2010 | 07:08 PM
galant306m's Avatar
may i ask how you did the timing? I need good way to check mine and see if it is right.
Old Jan 7, 2010 | 07:18 PM
Gordian79's Avatar
Good stuff.I never understood why people are so obssesed with how high a stroker revs if its making peak power at xxxx rpm why should you rev way past it.You always want to keep your motor pulling towards peak power going down the track.for sure you dont want it where power is on the decline.
Old Jan 8, 2010 | 06:46 AM
tscompusa2's Avatar
OMG @ those numbers on 25 psi and pumpgas/mix
Old Jan 8, 2010 | 07:20 AM
nabilsx's Avatar
what are the numbers?? I cant see the graph its black on my screen, you got me all excited guys.
Old Jan 8, 2010 | 07:25 AM
SloRice's Avatar
444wtq, 433whp, peak torque at 4000RPM, 25psi tapering to 22-23psi, 93 octane.
