Mikey's E85 FP Red 535hp
Old Feb 19, 2010 | 08:05 AM
  #31
s.e.a.n.'s Avatar
Nice power some nice set of cams would definitely make a difference.
Old Feb 19, 2010 | 08:26 AM
  #32
JohnBradley's Avatar
Daniel, new 5 bar MAP sensor. I swear we have more bad luck with MAP sensors and WB with that dyno. Least I have the 4 bar and a Tru Boost for recall in most cars.
Old Feb 19, 2010 | 09:30 AM
  #33
yahu's Avatar
I know you guys have fought that beast on and off. See you tomorrow Aaron - I got a little box for you, courtesy of the Glen!
Old Feb 19, 2010 | 09:35 AM
  #34
BLKCarbonEVO's Avatar
I'm loving my Tru Boost! Great reccomendation Aaron.
Aaron, do you think you could meet me at DO on March 6th for a good pump tune. Then maybe again on the 13th for tuning the new R/TErnie upgrade? I want to have a good pump before and after and E85 before and after. Thanks Aaron!
Mikey
Old Feb 19, 2010 | 10:32 AM
  #35
1slowassevo's Avatar
Mikey
Mikey the red and black use the same exact cover there both 84 mm in size...Now for sounds they sound identical to each other..
I can't wait to go for a retune to see if i can hit the same or close numbers as you cause the red really shines in the 32 to 33 psi range..
How much boost are you holding to redline???Looks like 25 psi..
Old Feb 19, 2010 | 10:48 AM
  #36
Well I have never heard the Black in person but Yahu has had both the Red and Black with 84mm cover and he says the Black is louder...
Ya I would have loved to push the Red into the 33psi range but my tq on 30-31psi was already 440... So we stopped pushing it.
What is your hp/tq and how many lbs? I don't have my logs in front of me but I believe at 7850 it said 25.84ish... Something like that.
Mikey
Old Feb 19, 2010 | 10:55 AM
  #37
Mikey
Remember i had 490 whp and 430 tq on 30 psi with some.boost leaks!!..With my boost leaks fixed i hold 30 to 29 psi till 7,800 rpms...I wonder why your only holding almost 26psi????
Old Feb 19, 2010 | 10:59 AM
  #38
O ya that's right. I can't keep people straight on here. I think it is my cams and my 18psi wastegate that has 0 preload! I had minimul prelaod to help counter some of the low end tq. However that is prob hurting me out the top too. What cams do you have?
Mikey
Old Feb 19, 2010 | 11:11 AM
  #39
Mikey
LOL .....I have the 18 psi hp wastegate that came with the turbo from forced performance and i have not touched the preload at all since it came out the box it might have to be the combo and the tune..
Imagine if u held 29 psi on top what the car would feel like and make...Im running stock bumps..
Old Feb 19, 2010 | 12:11 PM
  #40
xcelr8's Avatar
Mikey, when you were going up on the boost you were losing TQ?
Old Feb 19, 2010 | 12:44 PM
  #41
Ya I would love to hold 29psi out the top. It may hapen soon. We are making some significant changes in the next few. I'll keep my thread updated.
No! The more boost you run the higher your tq number. My car usually makes on average of 80 more hp than tq between 29-32psi. Anything over 32psi on a red will really start to produce more tq more per psi than below 32psi. There is a lot of reasons behind this... Cylender pressure and intake air temps raise a great deal over 32-35psi. For example. My car makes roughly 12hp and 8tq per psi between 28-32psi. I have not ran more than 31psi on my stock motor but if I did I would expect I would make the same hp and tq per psi between 32-35psi. Then anything between 35-40psi would tend to make a lot of tq and minimul hp... Maybe 5hp and 15tq per psi.... See how that kinda works?
Mikey
Old Feb 19, 2010 | 01:15 PM
  #42
Mikey
I agree somewhat about what u should thats why in gonna go to only 32 psi max with 1 extra degree or 2 of timing....
Old Feb 19, 2010 | 01:37 PM
  #43
^ what fuel are you running? Corn?
Old Feb 19, 2010 | 02:01 PM
  #44
cesare77's Avatar
Very nice job
Old Feb 19, 2010 | 02:12 PM
  #45
100% percent meth with 93 oct.......I wish i was running e 85
