4g64/MIVEC/FPBlack e85/92 Comparison
Old Apr 4, 2010 | 08:21 PM
AcePitcher11's Avatar
Since your tuned on e70 how much will it effect the tune whenever it becomes true e85 and will it effect it in a bad way?
Old Apr 4, 2010 | 08:42 PM
Spoolin4g63's Avatar
sick power band! its amazing what that FP BLACK can do!
Old Apr 4, 2010 | 08:55 PM
yahu's Avatar
I would guess not, but he could theoretically get more out of the change with a proper tune.
Old Apr 4, 2010 | 10:04 PM
JohnnyTSi's Avatar
The switch to e85 will lean the A/F out a point or two, Aaron is so conserviative on their ethanol tune I'm not worried about it. The car will most likely pick up a few more hp as well.
John-
Old Apr 6, 2010 | 08:56 PM
JohnBradley's Avatar
The split is pretty easy to calculate for the fuel change-
E70- 0.5 richer, 2* less timing at peak torque same out the top
E85- Tune is zero'd out for max power
E98- 0.5 leaner, 2* more timing at peak torque same out the top
Or something like that depending on combination.
Old Apr 8, 2010 | 12:04 PM
tupac1's Avatar
Sick results why cant we get results like that here in OZ.
Qtn; what did you mean double pumper was "both modded"?
Cheers
Old Apr 8, 2010 | 12:38 PM
605REvolution's Avatar
Congrats on the results and sweet set up!
Old Apr 8, 2010 | 05:53 PM
batty200's Avatar
Cheers
both fuel pumps are modded.
Old Apr 8, 2010 | 08:05 PM
u189961's Avatar
grats on your new found power! FP black + good parts + good tuner = lots of win!
Old Apr 8, 2010 | 08:13 PM
JohnnyTSi's Avatar
Cheers
Correct, I punched down the pressure relief valve on both fuel pumps.
John-
Old Apr 9, 2010 | 05:22 AM
tupac1's Avatar
Hey Johnny sorry but how reliable are the pumps when you do this?
I have double pumper also and was thinking of possibly going down the same path.
I have read it done before but thought it was too unreliable so not many people do it.
Cheers mate
Old Apr 9, 2010 | 05:29 AM
JohnnyTSi's Avatar
Cheers mate
I haven't heard about any walbro failures directly blamed on the pressure relief valve mod.
plenty of regular dead walbros though, It would be interesting to see how many of the dead pumps had the mod done!
John-
Old Apr 9, 2010 | 07:00 AM
Mellon Racing's Avatar
no failures here doing that but it wasn't necessary until I tried to go beyond 600awhp on e85, I also needed a fuel rail
Old Apr 9, 2010 | 08:13 AM
Kasey's Avatar
Nice setup Johnny and nice job with the tuning Aaron.
Old Apr 9, 2010 | 02:54 PM
Aby@MIL.SPEC's Avatar
Nice looking power curves.
what clutch set-up are you running?
