4g64/MIVEC/FPBlack e85/92 Comparison
Old Jun 9, 2010 | 02:12 PM
  #91
BLKCarbonEVO's Avatar
Originally Posted by boostedwrx
The Shearer is $343. Hopefully I'll do a back to back test with it on my Black soon.. If the bills ever stop rolling in!
Is that for the 2.5" or 3" housing. If that is the 3" then they came down a **** ton since last time I talked to Shearer!
Mikey
Old Jun 9, 2010 | 02:41 PM
  #92
tscompusa2's Avatar
http://shearerfab.com/blog/?cat=15
390+282 i need to ask him how much loss recirculated back into downpipe will be.
http://shearerfab.com/products.php?sub2id=16
Old Jun 9, 2010 | 04:27 PM
  #93
Good to see the price came down and they switched to the vband like I have, weird... Someone should be getting paid for coming up with all these designs that the shops are now producing!
Mikey
Old Jun 9, 2010 | 05:09 PM
  #94
JohnBradley's Avatar
long tube recirc will be just as efficient as dumping to the ground? if so id be interested in that mod....... the only reason i didn't do a dump was because i didn't think it would make much diff recirculated rather then dumped.
The further away from the turbine housing before it gets reintroduced the better. With that being said there is no way other than to test and know for sure. It seems reasonable it would work better than nothing but I will admit it will probably not be as good as external.
aaron
Old Jun 9, 2010 | 05:24 PM
  #95
Erik@MIL.SPEC's Avatar
aaron
Doesn't MAP make a divorced wastegate/downpipe combo?
Old Jun 9, 2010 | 05:34 PM
  #96
Correct
Old Jun 9, 2010 | 10:38 PM
  #97
But it is MAPs, I'm sure you can make a better design Erik!
Mikey
Old Jun 10, 2010 | 01:02 PM
  #98
RockmanX's Avatar
you need a custom made downpipe to use that shearers dump correct??
Old Jun 10, 2010 | 01:41 PM
  #99
Correct. Their new design now has a Vband and they sell the Downpipe too. It is a little over 500 for both the housing and the dp.
Mikey
Old Jun 10, 2010 | 02:30 PM
  #100
RockmanX's Avatar
Mikey
wow ill pass for now
Old Jun 10, 2010 | 02:48 PM
  #101
Old Jun 10, 2010 | 07:19 PM
  #102
BIGJEFF's Avatar
That's sick good numbers I can't wait to get my E85 tune. Congrats on the results
Old Jun 10, 2010 | 08:15 PM
  #103
tscompusa2's Avatar
I found out my invidia o2 was 2.9" close enough to 3". the only thing I didnt like about the invida was you had to reroute the o2 sensor wiring but it didnt take long - something you could go with rock.. the megan and ebay o2's are only 2.3" - very restrictive.
Old Jun 10, 2010 | 08:29 PM
  #104
RockmanX's Avatar
there was a test ran awhile ago and the ebay ss o2 came out on top buddy and showed good gains
Old Jun 10, 2010 | 08:37 PM
  #105
It really doesn't matter how large the housing is... The part you are forgetting is the 2.5" donut flange. It will only flow as good as it's smallest diameter will allow it too.
Mikey
