Virtual Dyno is available!
Old Jul 12, 2010 | 11:01 PM
  #91
bsmart82's Avatar
Thanks to everyone that made this possible, been waiting patiently.
3" Buschur exhaust
Buschur air filter
MBC@24psi peak
Self tuned
93oct
Old Jul 12, 2010 | 11:02 PM
  #92
Mellon Racing's Avatar
Originally Posted by tscompusa
lol good i was hoping he would get the hint lol. youll have him ripping in no time when is your motor going back in car man? been a very long time now.. arent you going nuts? or do you just use the 3000gt etc to take your mind off the evo?
we're going to shoot for 400/400 and go from there
I've had so much on my plate to deal with this past year that I nearly forgot about the EVO The new 10:1 engine is here and it's going to be installed when it's my turn, hopefully soon. With the EVO being down I've made time to fix a few nagging issues on the Stealth and VR4, both are nice to drive now.
Old Jul 12, 2010 | 11:03 PM
  #93
Testing 1.4 final tonight I ran a customer's EVO X AP tune vs ECUFlash tune through VD for comparison. I tuned it both times and the AP data is old when he was running stockish boost and no wb02 so I couldn't push it too hard. I thought it was neat to be able to compare runs from two different devices. If we don't find any more major bugs this could be released very soon
Release Notes
1.0.4.0
- Fixed a bug where logs could have blank data in some cells and data in others of the same column
- Added AEM log support (must be exported in TEXT format)
- Access Port (AP) logs now supported
- AFRMAP removed from the AFR column list due to it not being an actual measure of AFR
- Fixed bug where if AFR has empty cells it would crash
- Fixed bug that would graph cells that should have been trimmed by the TPS trimming, this caused graph anomalies
- Changed loading time of logs to only when first loaded, which prevents loading all logs everytime the graph is redrawn
- Changed colors to be Red/Blue for first run loaded to conform with most dyno graphs
- Trim out data samples that have the same RPM as the previous row, which causes anomalies and high HP numbers
- Trimming of RPM now is live and doesnt cause graph to blink
- Graph quick action bar added to top right corner of graph (wont show up on print outs, or screenshots)
- Save graph image added to quick action bar
- Copy graph to clipboard added to quick action bar
- Print graph button added to quick action bar
- Toggle data points added to quick action bar
- Color changes for uniformity
- Default CF set to 1.09
- Store default image for the graph background
- Limited loaded runs to a max of 4
- Default tire sizes for all vehicles were set to the stock tire size
- Legend wording reworked to show weight and remove one unneeded entry
- Tire size calculator button added to the RunControl, next to the TireSize text box
- Changed versioning to shorten the length of the version the user will see to 3 digits ex. (1.0.4)
Old Jul 12, 2010 | 11:08 PM
  #94
tscompusa2's Avatar
downloading** now that looks badass.
Old Jul 12, 2010 | 11:11 PM
  #95
it's not out just yet, we're doing final testing. I'll be able to do more testing as customers send in fresh datalogs tomorrow.
Old Jul 12, 2010 | 11:15 PM
  #96
tscompusa2's Avatar
ah ok ya i didnt see it lol. Looks like he changed the way the lines look now? Looks better and better each time.
Old Jul 12, 2010 | 11:20 PM
  #97
yep, instead of using two colors for each runs, it's just using one color, solid and dotted. Much easier to compare runs especially when you have three in there.
Old Jul 12, 2010 | 11:21 PM
  #98
tscompusa2's Avatar
agreed. i love it.
Old Jul 13, 2010 | 04:16 AM
  #99
Boost_Inspired's Avatar
To my previous tuners defense he lowered the boost from 29 to 27 psi because I was getting a throttle hang after pulls at 3800 rpm and if I depress the clutch it continues to go back to normal idle. He thinks it's my stock pressure plate but I've been researching and it seems like the decel fueling tables are not adjusted correctly. This dyno was on e85 and 27 psi btw
Old Jul 13, 2010 | 05:15 AM
  #100
Boosted Tuning's Avatar
I found a couple bugs in the latest beta. Got debug logs for brad. Hopefully it will be done after this fix.
agreed. i love it.
I kinda recommended that. Your welcome.
Also, doesnt everyone love how ALL the info is on the chart? I do........ I recommended it.
Old Jul 13, 2010 | 08:04 AM
  #101
bbarnhill's Avatar
Sorry to shoot ya down ... but Ive had every beta tester at my throats about this
Old Jul 13, 2010 | 10:43 AM
  #102
PeteyTurbo@KHC's Avatar
I can't imagine why anyone would NOT want this. I also can't imagine data without it being taken seriously at all.
Old Jul 13, 2010 | 11:51 AM
  #103
nonschlont's Avatar
I agree. Lookin forward to the next release...
Old Jul 13, 2010 | 03:42 PM
  #104
bbarnhill's Avatar
OK OK OK ... 1.0.4 has arrived people. Any changes from here out will go into 1.0.5
Enjoy the new look and feel. With each version maybe it will get a little more polished.
Old Jul 13, 2010 | 03:57 PM
  #105
l2r99gst's Avatar
Very nice. I'm going to have to get some new logs to run through this again.
