EVO IX Stock Motor 6262 93 Pump
jeez... idk if i want that really. this whole turbo choosing for my car is really becoming a pain. i cant tell you how many times i have changed my mind on what i want to do with the car. recently i am leaning towards the 6262
I want to do a little something like that too.
I want to switch out my BC272's that came with the car with some GSC s2's and beehives. Then put some studs in for peace of mind as well.
I couldn't really tell by the video, but what kind of manifold do you have?
stock intake and old buschur exhaust manifold
No it will just prevent you from having valve float and flutter thus resulting into more constant power and fast spool.
You mean the Buschur cast Turbo manifold? ? Nice setup but for 28 Psi with this Turbo your power is very low ..at this boost level you should be around. 500whp easy or more unless your * is low.what came do you have? ?
Well the tubular manifold is good for 30 whp do you know what the * is???the hks 272. Cams are decent but I still think 500 whp at 28 Psi should been hit still..my friend just got tuned with the same Turbo but he Put down 520 whp on 27 psi it makes 550 or so on 30 psi.with conservative *.
L@ncer knows what can be done to improve his power and most importantly his times. I know your trying to help, but it seems like your trying to run his car wash after he has owned it for years
Ok cool but the fact of matter is its underpowered for.a 6262 on 28 psi pump gas ..do u work at jms racing?
