Evo 8 RS + FP Green 73HTA + boltons
Old Jan 9, 2011 | 09:15 AM
  #46
tdubbz's Avatar
I don't pretend to be an expert on turbos but I do my research before I buy and the HKS hasn't been out all that long and there have been tons of those turbos on the F/S thread...thats a strong indicator to push to me over to the HTA or consider the BBK. Just my .02
Old Jan 9, 2011 | 10:06 AM
  #47
tscompusa2's Avatar
Originally Posted by killerpenguin21
thanks. so basically this is showing that it can make 400whp or thereabouts on only 23psi and its netting a little less than 10whp per pound of boost...damn im continuing to be impressed.
Yes. The detailed boost plot is here of one of the runs: (renamed the omni bar to JDMMAP so it showed up by default in Virtual dyno)
Old Jan 9, 2011 | 10:11 AM
  #48
tscompusa2's Avatar
I have to agree. Id get the green over the HKS. The BBK series turbochargers are pretty nice also.
The HKS probably does have better transient response though.
Old Jan 9, 2011 | 10:21 AM
  #49
Boostme's Avatar
good numbers put down.
Old Jan 9, 2011 | 12:10 PM
  #50
killerpenguin21's Avatar
i like that boost plot, it holds dead on pretty much. the lack of taper is what i like, and the setup on the car is very close to what i would be looking at also.
my wallet is mad at you now LOL.
Old Jan 9, 2011 | 12:28 PM
  #51
aka.ralliart15's Avatar
I second that. I think the HKS is sort of like the Tomei when it came out, a lot of expectations but people really weren't satisfied, that's why you saw a lot of them for sale.
HTA Green would be my choice.
Old Jan 9, 2011 | 01:14 PM
  #52
zeus1's Avatar
Originally Posted by fabcas311
badass!!!!.......how about the reliability?
mine is not an hta but it has about 60k or so on it running pretty high boost.. (knock on wood)
Old Jan 9, 2011 | 09:40 PM
  #53
mkcolgan's Avatar
awesome numbers!
Old Jan 10, 2011 | 05:52 AM
  #54
tscompusa2's Avatar
It should be as reliable as MHI turbos, mitsubishi heavy industries. ive seen stock turbos last over 100,000 miles. I think your turbo will outlast your engine in all honesty as long as you lubricate it properly.
Old Jan 10, 2011 | 06:42 AM
  #55
zeus1's Avatar
i hope it lasts too... i use this stuff..http://www.amsoil.com/storefront/asl.aspx
Old Jan 10, 2011 | 06:59 AM
  #56
tscompusa2's Avatar
ya amsoil is great oil. 28psi is still not pushing that turbo either, so you should have lots of miles left on it.
Old Jan 10, 2011 | 10:00 AM
  #57
s.e.a.n.'s Avatar
im surprised you're not seeing it if you have e85. this car had another 10whp in it with timing, i just didnt wanna push it out anymore since 93octane varies from pump to pump.
lol I wish! My car made 420 on 25lbs. Not much boost for E85 but I had the stock head stud back then. I doubt I'll see 500 with a stock motor, stock cams on a old style green anyway.
Old Jan 10, 2011 | 11:00 AM
  #58
TakaseEVOIXSE's Avatar
great results w/ the HTAgreen and 93 octane.
-Tom
Old Jan 10, 2011 | 03:46 PM
  #59
420a-t's Avatar
Looks good! When does the boost start to drop off with this thing?
Old Jan 11, 2011 | 05:51 AM
  #60
tscompusa2's Avatar
you mean like if you turn the boost up at what psi level will it start to fall off? i dont know honestly. but right now its not dropping off at all really. But i think once it passes 30psi it will tapper down at higher rpm a little.
