Map built evo 8 2.4l fp black e85
If the MAP sensor is holding you back, have them pull my 4 bar out of my car, its at MAP now and try it
I assure you that after you see results on 34psi or more you will be like, OK I'll spend 100 bucks on an omni 4 bar
Maybe when I get a good clutch pointless to play with more boost if I'm gonna strip the pads off lol
Im sure the clutch is right around the corner the ACT will only be able to handle 550 so long
Assuming you are on the MAF still, in theory you can do that and the MAF will calculate for the extra air.
However, I always think you should tune for max power and dial it down if need be. Tunes are cheap insurance.
So in short, if you aren't good at monitoring/logging just get a tune
are you still running the ttp 6 puck?
i didnt have any slipping issues with the act sprung 6puck, however it did $hit itself after ~18k DD driving @ ~550/580 ft/lbs of love, every chance of clear road that i was presented with!
No I upgraded to a unsprung 4 puck and the Modified extreme Pressure plate.... no issues now lol but I'm still at 475 awhp. My preassue plate was pretty wore out before. it's had about 35000 miles on it
