FP Black on 93 with water/meth
Old May 4, 2011 | 12:28 PM
  #31
KevinD's Avatar
The dds3 is the control board for both the hfs1 and hfs5. The new kits use a different board setup all together. Yours will either have a low speed valve (hfs1) or a high speed valve (hfs5). The hfs 5 offers a proportional meth delivery following the injector duty cycle. The hfs1 is a on/off switch based on the duty cycle trigger point. Both ways work well. The hfs5 will change flow on the display gauge though depending on how much duty cycle your injectors have. The actual volume of meth your flowing depends on how many and what size nozzles your running, and also what system your running, so for the hfs 5, if you hit a max of 70% duty cycle, your only going to flow 70% of what the nozzles are rated for.
Old May 4, 2011 | 06:31 PM
  #32
pluto's Avatar
Kevin,
I think brian has the aquamist setup and activated the aux N2O map (timing and fuel). From what I remembered, its probably around 10% of the total fuel injectors since he took out 10% of fuel on the aux map.
Old May 4, 2011 | 06:55 PM
  #33
JYD's Avatar
JYD
Originally Posted by LGshow19
Thats not as high as i was thinking. Thanks for the info.
Fort Worth, thats too far for me. Looks like Austin is still the best option.
Keep some updates coming when you get the parts rolling
KevinD in dallas is worth the drive. dont waste your time with anyone in austin. i live here, and wouldnt trust anyone here to tune my car. especially after Kevin hooked mine up last weekend. i have regular bolt ons, and he picked up 40hp and 60 ft lbs. this is on the same dyno as the OP.
Old May 25, 2011 | 03:05 PM
  #34
Sandroc's Avatar
Finally got the dyno sheet back. Also Kevin when could I get a chance to see the other car with a FP black in it?
740 Turbo Brick
Jul 25, 2016 03:09 PM
EvoLucio
Mar 9, 2016 09:42 PM
evo9ben
Dec 20, 2010 05:19 PM
TTP Engineering
Jan 26, 2010 04:56 PM
tephra
Sep 14, 2009 07:15 PM
