'05 Evo8, GSC S2 cams (317whp/322wtq)
Old Jan 17, 2013, 03:55 PM
  #46
Dynotech Tuning's Avatar
Originally Posted by mitsubeastlee
And i thought all mustang dynos were created equal lol.
Unfortunately the Mustang Dyno is only as consistent as the operator allows it to be. The shops that keep them 100% properly calibrated to MustangDyne's settings are very consistent with each other. A lot of shops will alter the paramters to simulate neighboring dynojets in their area.
Kings Performance sets their Mustang Dyno to emulate Dynojet results and openly makes this info available without hiding the fact. They just preferred having a loaded dyno but preferred sticking with the dynojet results they are accustomed to. It does make it confusing when trying to make power comparisons across the country though.
-Jamie
Old Jan 17, 2013, 04:22 PM
  #47
mitsubeastlee's Avatar
-Jamie
right on, ill have to ask around and see what others say regarding the settings and numbers they made.
Old Feb 5, 2013, 12:21 AM
  #48
jeremy52048's Avatar
great numbers, hopefully my 05 can do similar, how many miles does she have?
Old Feb 6, 2013, 03:36 AM
  #49
andrewr's Avatar
The car just kicked over 60k
Old Jul 2, 2013, 05:21 AM
  #50
Deano_Engineer_'s Avatar
How much of a difference do upgraded cam gears vs stock cam gears make with the S2's?
Old Jul 2, 2013, 05:39 AM
  #51
They can make a sizeable difference if the cams weren't actually on the centerline they are supposed to be at. They can be off from manufacturing error (GSC's are quite consistent though) or from having the deck and head milled a great deal. Once the cams have been properly degree'd with a dial indicator, you now know the true centerline of each cam. From that point, you can make adjustments on the dyno which can help shif the powerband where you would like it to be.
-Jamie
Old Jul 2, 2013, 05:47 AM
  #52
You guys are going to end up doing an S2 cam and timing assembly setup for me shortly. I already have a quote but what are your favorite cam gears to use that I should look into?
Old Jul 2, 2013, 06:05 AM
  #53
We can get you the AEM cam gears. They are affordable and they offer 5 locking bolts compared to only 3 by others, like HKS. We can send you a revised estimate including the cam gears if you'd like.
-Jamie
Old Sep 14, 2013, 12:41 PM
  #54
GrandMasterKhan's Avatar
wow didnt know the stock turbo could do that. impressive
Old Sep 14, 2013, 03:23 PM
  #55
JaYr_EvO9's Avatar
Jamie tuned my car great guy !!!! I made 310hp and 300tq on a conservative tune with my current mod list added some cams and some e85 and see what i do !!!!!!!! These number were on a mustang dyno
Old Feb 18, 2014, 09:54 AM
  #56
Eray519's Avatar
I'm running a similar setup and I'm pretty excited to see how this plays out!
Dynotech Tuning
Aug 21, 2014 12:41 PM
Dynotech Tuning
May 29, 2013 07:50 PM
Dynotech Tuning
64
Dec 14, 2012 04:36 AM
Dynotech Tuning
Dec 9, 2012 07:03 PM
Dynotech Tuning
Evo X Dyno Results
50
Feb 27, 2012 08:13 PM
Quick Reply: '05 Evo8, GSC S2 cams (317whp/322wtq)
