Evo9 turbo vs BBK Full (journal)
Old May 29, 2011 | 11:54 AM
  #121
PoloTurbo's Avatar
Like my last turbo it seems laggy compared to evo9 stock turbo
I swapped back the stock 9 and gained 500rpm+ in spool.
The top end isn't even near...but daily from 2000-5000 is in fact more fun.
I guess the GtII 7460r is the best of both worlds.
Old May 29, 2011 | 11:56 AM
  #122
Thoe99's Avatar
Originally Posted by MJ23FE
Great job!
Is it me or does it seem like both your stock turbo and BBK both spool up slower than I've seen before?
-Jalal
Yep, I have a suspicion it's because of the boost leak I'm experiencing.
Old May 30, 2011 | 12:32 AM
  #123
Thoe99's Avatar
Results are completed. I detuned all sporadic knock for these results. I also updated post #1.
Attached Thumbnails Evo9 turbo vs BBK Full (journal)-bbk-vs-evo9-turbo-chart.jpg
Old May 30, 2011 | 12:42 AM
  #124
Thoe99's Avatar
fixed a slight error in the chart
Old May 30, 2011 | 03:19 AM
  #125
Jason's Avatar
Wow nice !! Thanks for the results. Spools Almost the same but tons more power
Old May 30, 2011 | 05:49 AM
  #126
InitialE's Avatar
Nice and methodical comparison. Thanks for following through with it!
Old May 30, 2011 | 09:25 AM
  #127
LGshow19's Avatar
Pretty similar in spool and a good amount of power. Only 24psi as well. At the same boost level you knocked off 0.32 from the 4000-7000 range. Looks like you definitely will be faster at the Drag Strip
Nice comparison man. That is some good testing.
Would like to see what gains you see whenever you turn up the "wick"
  #128
scheides's Avatar
EvoM Moderator
Originally Posted by Thoe99
Btw, CRBD was just about dead on when he told me to expect about 150rpms is added lag over the 9 turbo, which in my test cases have translated into a quarter of a second lost going from 2500-4000rpms. I like to benchmark that range because it's used quite often in autocross. .25s sounds like a lot for autocross, but in 2nd gear, it's considerably less, but then again, I have lost by hundredths of a second before, lol.
That is a great test! If/when you upgrade your FMIC, do the same test. Like I said before I felt no difference, but since you are obviously good at comparing data, go for it!
Originally Posted by thatguysmells
Is it worth it to buy this turbo? I'm thinking about getting it but my friend made 415 wheel on e85 with a stock ix turbo. Then I saw a forum on here where someone was making 437 wheel with a BBK full on e85. When I saw that it didn't see like it was worth it. Do you think it is?
Peak whp vs power under the curve my friend. I asked myself the SAME question and since I had a mapswitching setup with aquamist alky injection I can confidently say that BBK on pump > IX turbo on alky/e85 (cost aside):
Basically, 25whp peak difference is not much, but at 7500rpm its more like 65whp If you can do e85, its worth it. If not, this is the route to go IMHO
I tend to value the area under the curve more so.
Exactly.
It's funny you mentioned this. Throughout the day, as I was conducting runs and tests, I failed to pay attention to the butt dyno, and only paid attention to the road, my tach and my knock light. So at the end of the day I just drove around, feeling the car out. 1st gear was useless (it went through in like 30ft), 2nd gear planted my head back to the seat til redline, and 3rd just pulls hard way past redline. The power is amazing, but the power after peak torque kept pulling and pulling. It's definitely noticeable over the evo9 turbo .
Glad to hear you are moving to the end of tuning and getting time to ENJOY the new setup!
This data is amazing. If everyone did this level of comparisons (and published them) the world would be a better place. Great great data, thank you for sharing!
Old May 30, 2011 | 09:44 AM
  #129
InitialE's Avatar
Yeah, I think a nice big FMIC + less restricted LICP + 26-27 PSI should increase that AUC by quite a bit.
Old May 30, 2011 | 10:07 AM
  #130
Thoe99's Avatar
This is interesting. Going purely off these numbers, if the stock 9 turbo flows 44lbs and the BBK Full flows 51, that's a 15.9% increase. That'll bring my current power to 384/373 (me likey!). But in the real world, I know that's not how it works, heh.
Reading the threads again, I did have some pulls (when it was running a razor edge tune) that put the car around 380whp . Torque didn't proportionally go up, but it's cool to throw the initial guesses on what affects what, and to see how close the results are to it.
Old May 30, 2011 | 10:22 AM
  #131
Thoe99's Avatar
delete, chart didn't scale properly with rpm (anyone good with excel and knows how to overlay graphs correctly?)
Attached Thumbnails Evo9 turbo vs BBK Full (journal)-chart-boost-airflow.jpg
Old May 30, 2011 | 10:54 AM
  #132
Thoe99's Avatar
Alright, got the charts to work. This is a boost and airflow comparison between the two turbos. So I guess the 325rpm peak boost lag that the other chart reports is not very relevant. In this graph, it shows boost only lagging by about 150rpms. This is great because it reinforces the idea that peak numbers do not always tell the whole story.
Old May 30, 2011 | 08:50 PM
  #133
blackenedwings's Avatar
Excellent work on the comparison. Pretty much exactly what I expected... and the best thing is you have plenty of room to grow. Because the efficiency range of the BBK will scale even more efficiently with higher boost than the IX turbo, it starts picking up a lot with a couple more psi thrown at it.
Old May 31, 2011 | 07:31 AM
  #134
CBRD's Avatar
Thanks for posting, I need a little more time to re-read back through (long weekend) but I do appreciate your data and testing!
Cheers
CB
Old May 31, 2011 | 08:46 AM
  #135
Thoe99's Avatar
Cheers
CB
No problem at all! I enjoyed the process and it makes me appreciate my hardware that much more. I'd be more than happy to do some independent 3rd party analysis of CBRD's great intercooler if one came my way
adib
Mitsubishi TC-SST Discussion
Jul 14, 2016 11:21 PM
mrfred
Dec 31, 2014 08:27 PM
Gary@MellonRacing
56
Jun 30, 2011 10:54 AM
dmotors
May 9, 2011 08:27 AM
donour
Dec 2, 2010 08:42 AM
