Evo9 turbo vs BBK Full (journal)
Old May 25, 2011 | 05:04 PM
  #76
Thoe99's Avatar
With my downpipe dumping into the open and being able to hear the turbine spinning, I like to describe the sound like a tornado The whistle is almost emergency siren like. At low rpms, it's quite ominous.
I went out and did a pull after dialing the boost back to 24psi. It held 21psi at redline with a simple MBC (versus 19 on the evo9 turbo). Without tuning, it made 351/315 I did pick up more lag (few hundred rpms) and it was noticeable.
So with no tuning: +20hp/-7tq
Let's see what I can do with some tuning.
Attached Thumbnails Evo9 turbo vs BBK Full (journal)-evoscandatalog_2011.05.25_19.16.11-1st-pull.jpg
Old May 25, 2011 | 06:29 PM
  #77
Thoe99's Avatar
On that first pull above, I lost .4 seconds on the 2500-4000rpm area compared to the evo9 turbo.
I just added 1 degree of timing to my new tune at the 2500-4000rpm segment and it gained .15 seconds back ...no knock so far, this turbo loves timing in the midrange. More to go!
Old May 25, 2011 | 06:34 PM
  #78
LGshow19's Avatar
Looks good man... Keeps climbing all the way too 7k.
Get some logs when you get a chance. Keep it up man, good job!
Old May 25, 2011 | 06:40 PM
  #79
bambooi's Avatar
Use virtual dyno.
Old May 25, 2011 | 06:48 PM
  #80
MJ23FE's Avatar
I'd get rid of the Mobil1 and swap this stuff in ASAP. You're not supposed to use standard Mobil1 from what I understand with the CBRD turbo's. They recommend the Premium below, but the Z-Rod just came out so it's brand spankin new!
-Jalal
Old May 26, 2011 | 08:00 PM
  #81
Thoe99's Avatar
This is a work-in-progress. There still more I can do out of this. Tonight's tuning session ended abruptly with a cop hiding at the end of my tuning road . I started with roughly 3-400rpms lag using my old map. I'm chipping it away and it's looking awesome. This turbo pulls and PULLS past redline.
Here's the current standing so far against the evo9 turbo, both at 24psi. +35hp / +8tq with just a turbo swap.
And check out one of my anomoly runs The hp trajectory goes to the moon!
Attached Thumbnails Evo9 turbo vs BBK Full (journal)-comparison-evo9-turbo.jpg   Evo9 turbo vs BBK Full (journal)-evoscandatalog_2011.05.26_16.00.14.jpg
Old May 26, 2011 | 08:10 PM
  #82
Thoe99's Avatar
Here's the dyno graph for you people who relate to Virtual Dyno better. Almost the same.
Attached Thumbnails Evo9 turbo vs BBK Full (journal)-evoscandatalog_2011.05.26_20.59.11_vd.jpg
Old May 26, 2011 | 08:46 PM
  #83
scheides's Avatar
EvoM Moderator
Looking good man! Are you still on the stock FMIC? Get a big bad core on there if you can, and a 3-port BCS and make the most out of that combo!
Great gains though, I love the BBK!
Old May 26, 2011 | 08:47 PM
  #84
scheides's Avatar
EvoM Moderator
-Jalal
FWIW I ran my BBK Full for 20k miles on Mobile1 10w30 with zero issues.
Old May 26, 2011 | 08:56 PM
  #85
Thoe99's Avatar
Yea I'm on oem intercoolers. I'm starting to do my research on them. Am I going to gain more lag with an aftermarket one? More volume = more lag? I don't want anymore than I have now.
Old May 26, 2011 | 09:01 PM
  #86
LGshow19's Avatar
Do you plan to turn the boost up a little? It seem like the BBK will benifit from 2psi more or so...
Old May 26, 2011 | 09:11 PM
  #87
scheides's Avatar
EvoM Moderator
Everyone always says that but I saw zero spool loss on stock turbo with the buschur deluxe and I ran the race version forever. All you will see is more efficiency from all of the 'big' fmic's made to fit an evo. IMHO get a garret core fmic, i.e. buschur race or cbrd's fmic. Perrin one is great bang for your buck too!
Probably needs a bigger fmic before he can push boost. It's all about the combo guys, not just the turbo!
Old May 26, 2011 | 09:27 PM
  #88
Thoe99's Avatar
I'd like to run 28psi. What would happen if I ran that on oem intercooler?
Old May 26, 2011 | 09:43 PM
  #89
LGshow19's Avatar
You might get heat soaked since the OEM FMIC might not be able to keep the air cool.
What is your mod list?
Old May 26, 2011 | 11:09 PM
  #90
guest49582's Avatar
I'm really curious to hear more about the results.
