FP 71HTA 91 oct initial results
Old Jul 17, 2011 | 10:22 AM
supersnow's Avatar
I did a fair amount of basic modifications when I made the switch from 9 turbo to 71hta. My car was tuned initially on E-70 at 28 PSI with the following list of mods back in 2009:
BR TBE
MR O2 housing
ETS 3.5 IC and pipes
ETS Intake
APS Bov
1200 PTE
Walbro
I live in NM around 4200 feet of altitude; hard for small turbos to hold boost up top. I used the Virtual Dyno correction of 1.0 because I accounted for weather here which is around 17% on the low side. I dyno the car in Austin (dyno jet) on E-85 last May in it put down similar numbers to the E-70 graph showed here.
Ok, I got the 71HTA last month with the following mods to the car:
MAP 3" Dump (amazing work)
Map Rev 2 IM (stock port)
Mil.Spec 65 TB
Ported Hotside
I started tuning the car yesterday on 91 Oct; I'm learning on my own so I'm afraid to go with E-85 and break something. Obviously, the fuel curve look like a crap, I need to lean out the spool up and make it more consistent. The timing is almost dead on with 2 counts of knock at 6000 RPM...took a couple of degrees off. This is 26.5 PSI......can improve the boost curve a little bit more.
My goal is to put down 400 on 91 OCT, I think if I go SD and get a better tune it's possible on my set up without going to the S2 cams yet.
I would appreciate any tips on how to improve the tune
Attached Thumbnails FP 71HTA 91 oct initial results-e-70.jpg   FP 71HTA 91 oct initial results-91_26.jpg   FP 71HTA 91 oct initial results-comparison.jpg
Old Jul 17, 2011 | 11:17 AM
HsamehH's Avatar
i am surprised you run 11.4 afr 26.5 psi and 91 octane. what's your timing at peak ?
Old Dec 15, 2011 | 08:10 PM
ct9asilver's Avatar
Stock cams? List your complete mod list, if you left anything out.
Old Dec 15, 2011 | 10:09 PM
kyoo's Avatar
What cams? Is this compared to stock turbo and 71hta? Where does that slot? I recently picked up a hks 7460r, I picked up power everywhere over the stocker
Old Dec 16, 2011 | 09:12 AM
211Ratsbud's Avatar
https://www.evolutionm.net/forums/ev...a71-3d-sd.html
you should be able to crack 4 on 91 with proper AFR. Im a hair over 4 on 93, and fairly rich. enjoy!
Old Dec 19, 2011 | 05:32 AM
Levar's Avatar
Veteran: Army
I am a fan of 91-octane myself just for seeing what it is able to do since I live in southern Arizona with a similar altitude as yourself. I like the power the 71HTA is making on pump/91 but I, too, would be interested in knowing what additional mods you have.
ReaperX
Feb 16, 2016 05:38 PM
tscompusa
Sep 10, 2014 04:02 AM
a4rontran
Mar 13, 2013 07:54 AM
tscompusa
Oct 25, 2012 07:13 PM
hokiruu
Dec 14, 2011 09:42 PM
