Dubstar112's HTA71, 3d SD.
Old Oct 13, 2011 | 03:33 AM
211Ratsbud's Avatar
Im still tweaking some of the VE, so the fuel curve isnt optimal, but I started to get to the point where timing was moderate, and I was impressed with the fullness, and punch of the turbo.
14 @ redline, 4* peak torque, which is somewhat deliberately late, soon to add more just trying to be easy on the torque.
65* ambient
Stock intercooler, aftermarket licp
IAT sensor in the UICP
HKS272's
test pipe
aemwbo2 > ecu
FP 84 mm intake, and K&N filter
3dsd
buschur dp, megan o2
magnaflow ti with neckdown for stock type axle back
On the way, jm fab fmic
In the future skunk2 im, fb tb , coated manifold and hotside , Muse ic piping
Old Oct 13, 2011 | 05:02 AM
JayTS's Avatar
Nice outcome for such minimal mods. PM me with the pricing on the 71HTA I may be interested in upgrading my stocker for one of these..
Old Oct 13, 2011 | 06:29 AM
211Ratsbud's Avatar
It's a nice upgrade for sure . I was lookin for a stock turbo nut couldn't beat the price of this mild upgrade . My o2 housing is holding back for sure .. looking for dump and cop..
Old Oct 13, 2011 | 09:31 AM
killerpenguin21's Avatar
damn...
confused since the boost looks weird, this is on like 26 peak?
Old Oct 13, 2011 | 12:47 PM
211Ratsbud's Avatar
23psi vd ignores my column name and uses map lol
Old Oct 13, 2011 | 07:51 PM
BLK_EvIL's Avatar
looks good 93oct or e85?
Old Oct 13, 2011 | 09:44 PM
looks like the 71 is totally worth the money to me then
Old Oct 14, 2011 | 02:06 AM
211Ratsbud's Avatar
93 Oct
Old Oct 14, 2011 | 03:27 AM
211Ratsbud's Avatar
one thing i have a problem dialing in, is higher rpm tip in. it seems that no matter what i do i get real lean and knock when cruising at 5500+ and mashing it autocross style. I have mr freds advanced fuel options, and ive adjusted async tps factor, and async rpm adder both a substantial amount. ive also adjusted the VE/fuel maps. It just cant get rich enough fast enough.. Im going to give it a shot again after work with the fuel map again, Maybe I just need my AFR to drop faster? other than that no problems with drivability on my IX with speed density ie hiccups studders etc.
Old Oct 17, 2011 | 08:52 PM
jnut24's Avatar
nice numbers, cant wait to put mine on the dyno!
Old Oct 18, 2011 | 08:04 AM
211Ratsbud's Avatar
Still a few quirks with my SD tune but its getting there . I expect 340 on stm's dyno when I get it there but time will tell .
Old Oct 18, 2011 | 08:45 AM
BigT's Avatar
23psi and over 400whp? That is absolutely nuts. Good numbers.
Old Oct 18, 2011 | 02:32 PM
211Ratsbud's Avatar
I have seen ~400 consistently on DJ setting. Since I dont use that normally, but it tends to be what everyone here goes with. Id like to lean it out to about 11.5 solid, and go from there. Im still having a problem where higher rpm tip in doesnt get rich quite as good as it needs to.. How rich would you be at 6000rpm, 5 psi? would you be hitting 11.5ish already if you were at 6000 and mashed it?
Old Oct 18, 2011 | 02:45 PM
JuniorAWD's Avatar
Is this the same DubStar112 that had the 06/07 WRX?
Old Oct 18, 2011 | 03:44 PM
deadmeat's Avatar
That torque curve is awesome.. must be fun on the streets.
