Dubstar112's HTA71, 3d SD.
Old Nov 23, 2011 | 03:26 AM
  #61
211Ratsbud's Avatar
delete
Old Nov 23, 2011 | 03:41 PM
  #62
John@MooreAuto's Avatar
Hey man I know Jim- and you should definitely let him know. I'm sure he will take care of you. I can't wait to see what your 71HTA makes- I am about to get one for my RS.
Old Nov 23, 2011 | 03:53 PM
  #63
211Ratsbud's Avatar
I know, I installed it already, I was tooo anxious .. I will give them a cal Monday though. I doubt its going to hurt performance. I'm not even expecting a replacement either I guess Idk lol..
Old Nov 24, 2011 | 02:27 PM
  #64
211Ratsbud's Avatar
timing trace for the associated vd run. this is with the jmfab ic. I have to optimize timing yet, but theres the baseline with the setup.
Attached Thumbnails Dubstar112's HTA71, 3d SD.-timing-trace.png   Dubstar112's HTA71, 3d SD.-dyno-t-day.png
Old Nov 26, 2011 | 07:00 AM
  #65
211Ratsbud's Avatar
Added fp 18 psi wga!
Old Nov 26, 2011 | 08:29 AM
  #66
killerpenguin21's Avatar
I'm thoroughly impressed at this point
Old Nov 26, 2011 | 08:38 AM
  #67
BigT's Avatar
Yes, very. This little turbo is very promising.
Old Nov 26, 2011 | 12:13 PM
  #68
mirkendargen's Avatar
Yeah I'm pretty much sold on going for this turbo as well. It looks like it'll still be pretty nice on 91 (I may in general run 91 at the start of the year since the e85 prices will drastically increase ) but won't rip my block apart on occasional e85.
Not to mention how affordable it is!
Old Nov 26, 2011 | 01:20 PM
  #69
211Ratsbud's Avatar
I didn't see substantial gains installing my intercooler... But maybe due to conservation on my part ? Going to try and hook up ecu boost and get compensation to work as I've had no sucess with it before... Alt maps would be nice for kill mode
Old Nov 26, 2011 | 01:31 PM
  #70
ive never tuned cams, but your running half the mid range numbers i run on stock cams. i would think you shouldnt have to cut it that much just for cams. also, i think you could pull a tad more fuel out.
Old Nov 26, 2011 | 02:25 PM
  #71
BigT's Avatar
Turn the boost up and you should see substantial gains with the intercooler.
Also, heatsoak will be less of an issue...
Old Nov 26, 2011 | 02:39 PM
  #72
211Ratsbud's Avatar
Im running out of weather.. I need to get 400 ftlbs! No luck adding timing at peak boost though.. is my afr @ peak boost ?
Id expect my midrange to be a little flatter and have good gains 6k+ with cams though. Is this ?wrong ..
Old Nov 26, 2011 | 03:15 PM
  #73
id clean up that dip right before 4k, but i dunno how much difference it will make, i also have no idea how easy/feasible it is to smoothe it out with SD.
i dunno why, but my wide band reads a hell of a lot smoother than that.
Old Nov 26, 2011 | 03:27 PM
  #74
211Ratsbud's Avatar
Not hard to fix that but I don't have smoothing on my afr boost plots.. do you ?
Old Nov 26, 2011 | 04:03 PM
  #75
BigT's Avatar
Its all in the log. I noticed when I'm logging many items, and the samples per/sec is less, the graph is relatively smoothed out. When I log the bare minimum, the graph seems to be more sketchy/accurate vs being smoothed out.
