Dubstar112's HTA71, 3d SD.
Old Oct 18, 2012 | 09:24 AM
  #211
211Ratsbud's Avatar
Will gonna do some more work once I get this 25psi wga.
Enjoy the idle tho
I've switched roms and rescaled my kpa load table and the sas should be finished up in a few days
Old Oct 23, 2012 | 07:13 AM
  #212
Aby@MIL.SPEC's Avatar
im surprised to see your boost plot drop off so much up top. is that intentional?
have you tried any other bov's?
Old Oct 28, 2012 | 07:04 PM
  #213
211Ratsbud's Avatar
No i had STM weld my greddy on their uicp. I have the single spring mod and a 8mm line running to the top port
I'm fairly sure the wastegate actuator is at fault. I scored a 25 psi unit from sparky and will test later this week.. Switched back to hallman
Old Feb 24, 2016 | 02:29 PM
  #214
revhappy's Avatar
Originally Posted by 211ratsbud
still working though, leaning out slowly
25ish psi, having a real hard time with spool knock(gone for a couple days, then gets real bad again??? wacked out for sure), and light accel. I really cant see what the eff is causing so much knock! Once that gets good, looking for 475-500 vd/dj. My wb02 logs .2 low 99 percent of the time i get a clean pull in 3/4 gear this is clean btw
Any updates to this set up?
Old Jul 21, 2016 | 06:14 AM
  #215
cerevo's Avatar
Bump for update, you still using this turbo?
Do they even last this long?
Old Jul 21, 2016 | 08:09 AM
  #216
LetsGetThisDone's Avatar
They're built on a brand new OEM CHRA. So at the same boost, or in the typical 25-30psi range, it should last longer than a stock turbo.
211Ratsbud
Dec 2, 2017 06:50 PM
211Ratsbud
Jan 7, 2017 04:56 PM
tsitalon1
Nov 22, 2016 11:36 AM
evo4life94
Feb 26, 2016 11:14 PM
ReaperX
Feb 16, 2016 05:38 PM
