Best performance on pump gas stock turbo ix?
I was just curious I see tons of people using cams However I hardly see anyone using them in conjunction with upgraded intake manifold, exhaust manifold, cam gears, throttle body, etc.
Does anyone know how much you can see in gains by running all of these on 93? Also what do you think can be made on stock cams with the mods I listed.
Wrong section, To answer what i think your asking...
The stock 9 turbo will only flow so much before it turns into a flamethrower on 93 octane. The reason you rarely see people do ALL the mods you listed is because most of those parts stock work very well up to about 380-390whp. Which is also where the stock 9 turbo really runs outta steam on pump gas on a well set up bolt on car.
https://www.evolutionm.net/forums/ev...93-octane.html
Basicly you can throw $2000 at those other bolt on parts and pick up 15-20 WHP or spend it on a turbo and pick up 70WHP
Stock cams and stock 9 turbo cars with a few boltons on 93 make on average 320-360WHP
droppedrx7
Sep 20, 2009 05:25 AM
