Mark's 6266 2.3L 771WHP/603
Old Mar 14, 2012 | 09:15 AM
  #31
Mark_L's Avatar
Originally Posted by SDevo13
Don't suppose you have a graph in 3rd gear do you?
Awesome numbers btw
Originally Posted by SOEuro
did you do any runs in 3rd?
Also, kind of curious why you stop making power at 34PSI, that head must be moving some serious air.
No runs in 3rd. For a random data point on the street it hits 25PSI by 4400-4500 RPM in 3rd gear. And full boost by late 4K's. Not sure why it quit making peak power, or what the restriction point in the setup is, however I'm more than happy with the results! The turbo should live longer at lower boost too. The setup has surpassed my expectations.
Old Mar 14, 2012 | 09:18 AM
  #32
Mark_L's Avatar
Thanks for everyone’s comments! I have a video that I will post up later too.
Old Mar 14, 2012 | 09:50 AM
  #33
10isace's Avatar
This is what the Dr ordered! I've decided that a T3 manifold is the way to go for me, but never considered top mounted. Thanks for documenting. What size are the intercooler piping, 3"?
Old Mar 14, 2012 | 12:37 PM
  #34
Mark_L's Avatar
Out of curiosity, whats behind the questions about running it in 3rd gear?
Old Mar 14, 2012 | 12:42 PM
  #35
murlo26's Avatar
They are questioning the response looking so well and torque numbers I am sure Mark.
Or they just want to compare the setup to many other charts, which are all typically done in 4th.
English racing for sure and I believe most other shops that do 700whp+ evos all run them in 4th to my knowledge to get a better sampling for tuning, so not sure what the big deal is. For a high power car on a dynojet where you can't adjust the load I think its fine.
Old Mar 14, 2012 | 12:53 PM
  #36
vmrevo9's Avatar
Veteran: Air Force
if i remember correctly i have read that in 4th gear it seems to spool faster. i could be mistaken but thats what i remember.
with that said the spool characteristics are different between gears. so that is probably why they are asking for 3rd gear pulls
Old Mar 14, 2012 | 12:55 PM
  #37
murlo26's Avatar
What I meant by response and torque in my post is essentially spool (all directly related as more boost earlier = more torque).
Old Mar 14, 2012 | 12:58 PM
  #38
vmrevo9's Avatar
Veteran: Air Force
i know what you meant
Old Mar 14, 2012 | 01:10 PM
  #39
dtrackstar's Avatar
nice set up
Old Mar 14, 2012 | 01:14 PM
  #40
evo8dreamcar's Avatar
great numbers. must be a blast
Old Mar 14, 2012 | 02:09 PM
  #41
HIS Motorsports's Avatar
Wow nice Job Mark! Jordan is a good tuner too!
Old Mar 14, 2012 | 09:01 PM
  #42
-Evo Aaron-'s Avatar
Spool up is impacted significantly based on gear, so being that the vast majority of tuners dyno the Evo in 3rd gear it help give a better comparison to other setups and to what type of lag time/ response youll see on the street in a lower gear.
However regardless of that this setup does seem very responsive and is making some serious power for a T3 6266 at a very moderate boost level, very impressive indeed. and although that torque curve is an insane plateau, a good sum of that is because this is a 4th gear run giving the motor the time and load to spike that boost up hard and hold it for a long time given the longer pull due to 4th gear causing it to hold torque longer in a smoother (plateau like) line rather than see the rainbow like faster drop off you'll generally get with a 3rd gear pull.
Excellent results sir, thats one hell of a machine you have there.
Old Mar 14, 2012 | 09:02 PM
  #43
Holy run on sentence batman i just realized i tossed punctuation straight out the window on that second paragraph.
Old Mar 14, 2012 | 09:12 PM
  #44
SDevo13's Avatar
Yeah, reason I was asking for 3rd is comparison of spool. Keep in mind this is also 4.11 FD.
Old Mar 14, 2012 | 09:22 PM
  #45
scheides's Avatar
EvoM Moderator
You are such a rip. you guys have NO idea how fast this guy works and how determined he is! Just amazing. Nice car sir! Hope to see it around plenty this summer!
