BR's highest HP stock ECU EVO
Old May 12, 2012 | 06:27 PM
  #31
David Buschur's Avatar
Originally Posted by Bramage_Dained
How'd you like the cockeyed broken driver's seat anyway? It's been that way since the end of 2009, lol.
Oh and the UICP was from ETS.
I HATE the seat, not sure how you could drive it! I can't even reach the clutch so it's a PITA to try and tune, drive and hold the laptop! haha
Old May 12, 2012 | 06:28 PM
  #32
Originally Posted by AreSTG
thanks for the reply David. What is it you consider small runner (or now standard runner) at your shop? a 1.25"?
The smaller one is the one we consider small
Old May 12, 2012 | 06:29 PM
  #33
Originally Posted by thepoint4life23
So you going to be offering sd stock ecu tuning now
Yes, I have been doing them only because I hate seeing people go elsewhere and end up unhappy after I warned them. So I may as well take the money and warn then and then they can be unhappy! haha
Old May 12, 2012 | 06:33 PM
  #34
foxbear2277's Avatar
^^^^Lmao YESSSSSSSSSS!!!!!!!
Old May 12, 2012 | 07:02 PM
  #35
Spec-Ops1's Avatar
I may have to adopt this mantra! Great results Dave!
Old May 12, 2012 | 08:34 PM
  #36
Bramage_Dained's Avatar
Haha. I dunno, I guess I sort of got used to it. I drove from Ky->FL->MN, KY->MN->KY twice and KY->FL->TX->KY with it like that. That's why when I saw those seats for sale, and it was someone local to you I jumped on it
Old May 12, 2012 | 10:00 PM
  #37
s.e.a.n.'s Avatar
The combo is prefect good stuff DB
Old May 13, 2012 | 03:45 AM
  #38
EVO(boss)'s Avatar
Originally Posted by TopLevelPerformance
There u go sir
I missed this part
thanks alot man
Old May 14, 2012 | 11:21 AM
  #39
turboup's Avatar
good stuff!
Old May 14, 2012 | 03:00 PM
  #40
murlo26's Avatar
Very nice! I want a ride in this thing when you get back to MN
Old May 14, 2012 | 08:40 PM
  #41
Only if I get a ride in your X. I've never even sat in one.
Old May 14, 2012 | 09:56 PM
  #42
murlo26's Avatar
Won't be quite as fun as your beast, but I accept your trade
Old May 15, 2012 | 12:08 AM
  #43
Blue91lx's Avatar
I'm curious as to why you're so fond of the 2.3 motors, rather than all of the 4g64 combinations offered now-adays with better rod/stroke ratios and whatnot. (Not to sound condescending).
The reason I ask is that nearly every Buschur motor I see is a 2.0 or a 2.3 rather than a 2.4 or a 2.1/2.2 (4g64 based).
Old May 15, 2012 | 01:23 AM
  #44
AreSTG's Avatar
i believe a big part of it is if you already have a good block, why buy another
Old May 15, 2012 | 09:36 AM
  #45
RoadSpike's Avatar
I'll just assume this is the original SD rom. Dave I've found personally that the best way to get the fueling right at idle was to keep the VE table fairly high like 85-90% or so for the 500-1000 region and use the maf smoothing table in the 25-40hz range, may require a bit of rescaling, to adjust fuel down to a perfect afr. This will prevent the lean spike and get you the correct afr with the least amount of fuss.
