BR's highest HP stock ECU EVO
Old May 17, 2012 | 05:52 AM
  #61
tscompusa's Avatar
best double pumper for a evo period.. not even debateable. i cant count how many ****ty double pumpers i replaced with buschurs and it works everytime 100% flawless.
had one in my car now for going on 3 yrs and its rock solid with e85.
Old May 17, 2012 | 09:14 AM
  #62
David Buschur's Avatar
For those of you interested I did a couple of videos yesterday. One showing the dyno sheets and AFR differences and one with AEM logs showing the difference. They are posted on my Youtube channel or you can go to our Facebook page and click them there.
Old May 17, 2012 | 09:22 AM
  #63
ETS Michael's Avatar
Originally Posted by Bramage_Dained
Oh and the UICP was from ETS.
Your car is a beast!
Michael
Old May 17, 2012 | 10:04 AM
  #64
evo4nr's Avatar
Look forward to the 93 tune.
Could you let me know the IDC when you get done.
Old May 17, 2012 | 10:13 AM
  #65
nucci's Avatar
Originally Posted by David Buschur
This kind of crap has now cost me 3 days of work, 3 trips on the dyno. Headaches sorting it out and trouble shooting it, thinking it was ECU related etc. Hell Josh now has an AEM in the car when the stock ECU, had this been known, may have worked out.........in the end it runs nicer anyway
Back on the dyno today to hopefully finish it up.
That has got to be one of the most expensive double pumpers in history, lol...
Old May 17, 2012 | 05:23 PM
  #66
Actually, since Josh is in this thread you can verify with him..... I sold him the AEM AT OUR COST, didn't charge him to install it, didn't charge for any dyno time beyond the first hour ($300), have charged for no trouble shooting either. We also didn't charge to take his POS double pumper out, fix it and re-install it.
Pretty cheap actually.
Old May 17, 2012 | 05:41 PM
  #67
JohnBradley's Avatar
An extremely good deal if you ask me
Old May 17, 2012 | 10:52 PM
  #68
Bramage_Dained's Avatar
Truth.
Anything Evo related in the future that I do will be with Buschur.
Old May 18, 2012 | 09:10 AM
  #69
nucci's Avatar
You are a cool guy for doing all that.
All I meant was that the initial savings by purchasing a fake instead of a Buschur double pumper, was definitely overshadowed by the labor and parts which were used to fix the problem! If he would have had the Buschur pump assy you would have two days of your life back, and the car might not be on AEM yet, it sounds like... Just pointing out that the bill for the BR double pumper is worth it because IT WORKS!
Old May 18, 2012 | 06:25 PM
  #70
SWOLN's Avatar
Glad to here this crank is working out Dave... What clutch is in this car?
Old May 19, 2012 | 02:29 AM
  #71
The 6-leg version of the QM twin with the newer "gear drive" hubs.
Old May 19, 2012 | 03:20 AM
  #72
boosted90's Avatar
Awesome power and awesome work. I need to head over and check those videos.
Old May 20, 2012 | 02:48 PM
  #73
mrfred's Avatar
Did upgrading the pumps setup fix the leanout? You probably wouldn't be surprised, but the stock fuel supply line causes a pretty massive pressure drop. I measured a whopping 16 psi between the pump housing outlet and the fuel rail at 500 whp of E85 flowing through it. Pressure drop goes as the square of the flow rate, so going from 500 whp to 700 whp should increase the pressure drop to 30 psi. Add 40 lbs of boost and 43 psi base pressure, and you've got two fuel pumps fighting against 110 psi of pressure. Not much flow happens at that much back pressure.
I'm sure that the custom fuel line from the double pumper outlet to the stock hardline helps reduce the pressure drop, but I'd still bet there's 20 psi of pressure drop between the pump housing outlet and the fuel rail.
Old May 20, 2012 | 03:08 PM
  #74
Interesting, it's pretty smooth compared to the other Quarter Masters I've driven.
  #75
Yes, I think I posted it fixed it in here, it's also in the videos. The AFR's went from mid 12's to 10.0:1.
