Megatron Meets TSCOMP Tune = Winning Combination
Funny Tom tells you that and its done and when you asked me about it you had this huge arguement about what pump to run and thats not the route you wanted to go yadda yadda. Its funny how I treid to tell you the right way to go but yet you didn't listen till Tom basially the same thing I told you months ago. And of top of that you sat and watch my tuning thread for the longest time before you bought your ef4. Now to me for you to go and swap all this out for a red was a waste of time when you saw how laggy my car was on a stock 2 liter you should have just bought the red when you were looking and not have wasted all this time and effort redoing everything 100 ****ing times.
I did not swap "all" out other than a turbo. I did not waste any time as I am still learning more each day. It is all trial and error, my friend. If the FP Red does not cut it, I will change again as like I said, I can spend my money how I want to.
At the end of the day, I can spend my money however I want to, my friend. Your opinion is just like every other opinion and I take them in accordingly. Some opinions carry more weight than others and in this case, Tom is my tuner and I trust him with my investment. To be frank, you did not give the technical explanation that Tom did other than "buy a double pumper".
Wow really I believe I said you don't have enough injector with that pos Dietchworks and you said it will be enough. How long did that last ya? I am not gonna argue with you about and your right its your money you do what you want. But when you ask someone such as myself for options about your setup and I have been at this game a long time and give you an honest answer, and you go and do something else that my friend pisses me off. Not cause you want to change turbos or whatever thats beyond it. Its your money you do what you want. Just face it your being a pain in the *** about your car. Trust me I know. You have become impatient just to get it running and whatother aspects your going through and its ok to admit you ****ed up. You took nothing I said into consideration other then in any of your build other then the injectors. So whatever man good luck on the build I just don't get what your doing anymore but whatever.
Making the best decision with what we got is the name of the game. Searching for the Holy Grail that may never be discovered.
I am also thinking about upgrading the Rev2 I presently have for the Rev3.
no my entire argument about your thread is the lack of planning or research. dude your just throwing money around and tossing out ideas without thinking things through. i know its not my money or setup but trying to help.
why would you spend 650 for the rev 3 when you can buy a skunk mani and have it ported locally for 550. stm has proved that bad boy makes good power.
you could have sent that 9 turbo in to get upgraded and rebuilt from fp instead of buying a used one. although turn around time may have been worth just buying the used one.
as for a prior statement made about a single pump failing, yes its based on your power level. a 400whp single wally will last a lot longer than a 500whp single wally. i wouldn't mess with 91 either. e85 is the best way to go in az, not because 91 is really that bad here but because of the cooling effect e85 has in our heat. i beat on mine whether it's 90 or 115 degrees and NEVER see any knock or have detonation.
