IX gt3076r maxed out?
Old Feb 18, 2013 | 03:12 PM
JohnBradley's Avatar
Originally Posted by Grimgrak
The shop says they have had 1g dsms with the same turbo and housing make 515 mustang whp vs my 424. However they do have more porting and SMIM. I really do want to keep my powerband without going to a bigger housing Plus a .82 in 5 bolt t3 is a PITA to find.
Same turbo but not same housing. The FP DSM housing is bigger and flows better than the 5 bolt 0.63 A/r.
Old Feb 18, 2013 | 05:23 PM
Grimgrak's Avatar
Interesting... well the tuner himself rocks a 50 trim on his dsm and makes 70 more ft/lbs of torque and was getting 450-480rwhp. AMS was saying the only manufacturer of the .82 turbines didn't make a very reliable product... hope they wern't talking about treadstone.
Old Feb 18, 2013 | 06:30 PM
It's not from Treadstone, it all comes from ATP they are just resellers of the recast housing. The thing is even a 0.82 5 bolt ford style is too small, it needs to be a T31 4 bolt or V-band.
Old Feb 19, 2013 | 10:35 AM
Grimgrak's Avatar
I guess the best test would be simply to disconnect my recirc wastegate and vent it to the atmosphere to see how much power i pick up.
Old Feb 19, 2013 | 01:09 PM
Vivid Racing's Avatar
You'd still pick up more power with the larger housing. I'd listen to Aaron (John Bradley) personally, he KNOWS his stuff, it isn't speculation and if it is he would say so!
Either way, good luck with your build and quest to max out that turbo, I'm in to see the results!
Old Feb 20, 2013 | 04:25 AM
warzywko's Avatar
I doubt it will do anything. Your problem is pre turbo not post turbo
The larger housing will do the trick
Old Feb 20, 2013 | 07:46 AM
mean4g63's Avatar
I'm liking the 3076gtx myself but just wondering if i wont get the extra 10 lbs/min flow if i stick with the .63 5 bolt o2 housing. Starting to wonder if headporting is the real next step rather than a new turbo....
the GTX3076 has the same problem as the HTA3076. the 30R turbine. Running a larger housing will help coax more airflow along with bigger cams "might" get you close. however the real problem is the turbine wheel sucks *****. The 3076 is a bad mismatch compressor/turbine. Over-rated turbo IMO.
If you want to stay garret then the hta or gtx3576+bigger cams is really your answer.
Old Feb 20, 2013 | 08:29 AM
Grimgrak's Avatar
If thats the case then the t3 vband housing from ATP is my best option.
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
What would a 1.02 housing do to my precious 4.5k power band :O Or could i go with the .63 option and still see top end gains?
Old Feb 20, 2013 | 08:34 AM
Brianawd's Avatar
3076 is one of the best street turbos you can buy. You just have to be smart when picking your supporting parts.
I made 562awhp and 484awtq on a old school FP3052,2.0,9.0:1,small SMIM, Old school hks272s, E85, 32psi dropping to 29 out the top.
Old Feb 20, 2013 | 08:40 AM
mean4g63's Avatar
1.02=the spool of a pte bb CEA6262 with 100+ less hp lol
Old Feb 20, 2013 | 02:45 PM
Grimgrak's Avatar
Perhaps the best thing to do is weld a nut onto the egr block off plate to measure exhaust manifold pressure. Anyone know if it's the upper or lower hole on the egr that is exhaust?
Old Feb 20, 2013 | 05:38 PM
Left side (no top/bottom). If you stare at the side of the intake manifold you can see how the "tube" is cast into it for the EGR.
Old Feb 20, 2013 | 06:46 PM
Grimgrak's Avatar
What are the #'s i'd be looking at that would indicate it's not a huge restriction and what # do you think i'm likely to see?
Old Feb 21, 2013 | 08:45 AM
Ideally we always want backpressure less than boost or no more than a 1:1 ratio. You run 30psi we'd hope to see no more than 30psi. I am thinking you well see more than that, how much more not sure, since the torque is starting to drop so drastically past 6200.
For reference on a 6262 we saw 34psi of backpressure at 27psi in 0.84 T4 housing.
Old Feb 21, 2013 | 06:37 PM
mean4g63's Avatar
- GT3076 has never been a good pump gas turbo because of the restrictiveness of the turbine wheel. However C16, E85/e98 people are able to coax an .82 housing to 50-52 lb/min range because of the anti-knock properties of the fuel.
- When you see the dyno comparisons between the GTX and the GT3076 you will notice there isn't much difference. The turbine wheel is the issue. I would be willing to bet the the GTX doesn't make much more power maxed out than the GT3076.
-There are LOTS of other turbos that outperform it. Case in point. Holset HX40 will absolutely blows it away. See below. Same car, same dyno, no other mods besides a turbo change to a Holset HX40 in a T3 .55 housing. 2.3L DSM, HKS 272 cams. Its also important to note that the GT3076 would NOT boost any higher than 30 pounds. It was done.
- I am not saying to go with a holset. However you can see how under performing a GT3076 is when a 20 year old diesel truck turbo blows it away. The HTA, EFR, and GTX turbos out perform anything a holset or GT turbo can make. Hence why I would drop that turd to a HTA3576 at a minimum. Or hell HTA3582 with give you some extra breathing room (but might be a bit laggier than you want)
