EVO 9 2.4L 6466 GSC R2 Cams E85 28psi
Old May 18, 2013 | 04:07 PM
EvoDan2004's Avatar
congrats on getting it running and tuned. that is for sure a 10 second car. just drop the 60 foot .10 and your there haha. once you get the fuel system fixed and can crank up the boost your talking sub 10s with ease. congrats. glad it all panned out for you
Old May 18, 2013 | 04:38 PM
CT9Asphixyation's Avatar
Thanks Dan. So far in mid 80 degree weather the temps are still normal so I think my cooling system is up to par which was one of my biggest concerns.
Old May 18, 2013 | 06:33 PM
17pstockcar's Avatar
Nice work guys, Great to see some videos
Nice time slips aswell
Old May 18, 2013 | 07:35 PM
Thanks! Btw, I'm uploading a video to YouTube right now which I will post here when it's done. Perhaps somebody can help me identify what is causing these noises I am hearing coming from my car.
Old May 18, 2013 | 08:09 PM
Can anyone please tell me what these noises are?
Old May 18, 2013 | 08:26 PM
tscompusa's Avatar
Originally Posted by Tonba
Great power and spool!
How are you finding the R2 cams tscompusa?
They definitely help low end. the car has really good response downlow and the spool was awesome for a 6466. some people don't realize a 6466 is a big turbo, it is a equiv of a 37R. (3788R)
Originally Posted by EvocentriK
Nice numbers. What's the point of high lift cams +oversize valves with stock head ports? I thought they were maxed flow wise at mid to low 10mm lift.
I don't know what you're asking. with a bigger valve opening its going to move more air and exhaust gases taking further advantage of the longer duration no? so they are working together. with a 2.4L and this turbo i think a 1mm over valve is not a bad idea. I am not an expert with heads though so i'm not going to act like i know what i'm talking about fully.
Are you saying that you feel there is no need for a larger valve than stock? if so i have been told that by a few others also.
Originally Posted by HsamehH
Tom do you like the R2 cams ,is there a noticable difference than the S2's ?
Well i didnt drive the car or get to feel it so i cant truthfully answer that without actually being in the car and comparing s2 to r2, but it would seem like the r2 are like s2's downlow, and then uptop they are almost as potent as s3's so its a cam thats the best of both worlds.
Originally Posted by browningderek
Lookin good! The R2 cams don't slow spool at all... that's awesome! What rpm does the power start to fall? 8300ish?
Its hard to tell that data since we're using evoscan and 7968RPM is the cut off logging limit for 1byte rpm, so we would have to enable 2byte rpm (which i refuse to do since its not accurate and results in inflation), but i am willing to bet it doesn't fall off ever in his powerband. The R2 are almost like a s3 uptop, and we both know the s3's are badass cams.
Originally Posted by CT9Asphixyation
I want to begin by saying thanks to Tom for putting in work so that I was able to make it to the track last night. That being said, the trip to the track went a little like this. I teched in at about 8:30, got in line and made my first pass ever with this setup at 9:30. I had NEVER launched the car at this power level before but I still managed a 11.3 @ 133 spinning hard through first and second with a 2.0 60'. Next pass was an 11.9 @ 129 because I missed second. The next pass was an 11.4 at 132 and my final pass before the track closed was an 11.1 @ 133, both with 1.9 60'. Traction is a huge issue as I have continental dws tires on factory pressure. I couldn't drop pressure because my gauge ran out of batteries lol. Track prep is awful on Fridays, no traction compound whatsoever. The car spools like a beast! Full boost by 4700 rpm on a turbo this size is no joke especially considering I'm on a non ported head, stock IM and stock TB. I couldn't be any happier with how my car runs and I cannot wait to get some better tires and upgrade my fuel system. More than satisfied with Toms tune and I would recommend him to anybody. Also fwiw, another forum member on here was indeed riding along with me during the VD pulls in case anybody was wondering.
Thanks Taylor awesome review and I appreciate the kind words! Reviews like this and results are what make me really enjoy doing this as a main career / income. I do nothing else but this and i put a lot of time into customers cars and make sure the customer is fully satisfied and is happy with the outcome.
Thanks again for choosing me to be your tuner!
Old May 18, 2013 | 08:28 PM
tscompusa's Avatar
http://youtu.be/EMeoPI8jAdQ
are you asking about the vibration? or what noise are you asking? the car makes a lot of cool noises.
Old May 18, 2013 | 08:45 PM
Lol that reallly high pitched almost metallic sounding noise when I apply and let off the throttle.
Old May 18, 2013 | 08:51 PM
01sporty's Avatar
taylor I love and hate your car lol this is Jose off Utah evos btw !!!!! Tom has a gift
Old May 18, 2013 | 08:54 PM
01sporty's Avatar
blown input bearing. I can post a video of mine it does the same thing.
if you are going and you put it in neutral while going it will go away its just a crappy design
Old May 18, 2013 | 09:21 PM
Haha!! Word man, didn't know if you were on here or not.
FML...How the **** could it be blown already? Improper installation? Less than 1k on everything, freshly rebuilt...It's important to note that it was doing this before I raced as well but I noticed it got worse on the way home from the track.
Old May 18, 2013 | 09:23 PM
01sporty's Avatar
launching is the main culprit. as well as that clutch you have chatters and that is hell on those bearings!!!! but mostly..... inferior design!!!!
Old May 18, 2013 | 09:26 PM
01sporty's Avatar
also who built your trans? I know jacks has an updated needle bearing upgrade but they only do it on their rebuilds
Son of a b!7ch. Do I have to pull the whole engine or can I just pull the trans to replace it? How much does that thing cost? Btw I never even launched the car before last night..
Old May 18, 2013 | 09:27 PM
John at Team Rip Engineering rebuilt it.
