EVO 9 2.4L 6466 GSC R2 Cams E85 28psi
Old May 17, 2013 | 06:51 PM
tscompusa's Avatar
First id like to make it clear the vehicles out of fuel & The elevation level is 4800ft+
This is one of those cars i just have to share. The engine bay on this vehicle is extremely unique and definitely one of a kind. I am really impressed with the spool up characteristics the 2.4 and R2 cams provided with the large 6466 turbo. This car spools so well for having such a large turbo.
Keep in mind the vehicle is out of fuel and only has a Walbro 416lph fuel pump on factory wiring (not rewired).
So the basic info:
ECU: Stock ECU / speed density - tephra v7 / mbc
State: CO / 4800ft~ above sea level
Temp: 77F
Dyno #: 588whp / 444wtq
Track #: 11.172 @ 133.94
Mods:
Block
-ASF 2.4L Standard Rod
-8.5:1 JE Pistons
-Carrillo H-Beam 150mm Rods
-Manley Crank
-ACL bearings
-English racing modded water pump
-Work done by ASF Machine
Head
-4G63 Mivec
-Bowl blended and chamber matched
-Cometic Head Gasket
-Supertech +1 mm oversize valves
-Kiggly Springs and Retainers
-GSC R2 camshafts
-ARP L19 Head Studs
-English Racing modded mivec cam gear, AEM exhaust cam gear
Turbo System
-PTE 6466 CEA turbo w/ .82 dual v-band ex. housing
-Tial MVR wastegate
-Tial Q bov
-JC Fabworks Manifold, Downpipe, Dumptube, I/C pipes, Intercooler, Intake and Exhaust
Fuel System
-Walbro 450 lph pump
-FIC 2150cc injectors
Drivetrain
- T.R.E. Trans HD 1st gear roller bearing, evo 8 3rd and 4th gear, gear detailing and shot peening.
- T.R.E. transfer case with Wavetrac diff, upgraded case bolts, shot peened ring & pinion.
- Exedy Triple HD clutch
Suspension
-Swift Sport springs on stock KYB struts
Brakes
-StopTech blank rotors
-Ferodo DS2500 pads
-Motul fluid
-Rebuilt Calipers
Wheels/Tires
-17x9 +35 Enkei RPF1 with 20mm Project Kics spacers in the front
-Continental DWS
Picture of engine bay:
Graph: (Very safe tune) (We will push it harder once he gets a proper fuel system in the car.)
Smoothing 1: (For reference only)
Update:
Car was taken to the local dragstrip 1 hr after the tune was finished and went 11.172 @ 133.94 Thats a perfect
mph for his dynojet #'s (588WHP).
Old May 17, 2013 | 08:24 PM
17pstockcar's Avatar
wow pic looks good, Do you have more you could post?
Spool looks really really good
Old May 17, 2013 | 08:30 PM
joseph143's Avatar
Its interesting that this car ran out of fuel.
Are you certain the scaling in vd is right? I tweaked a friends car and when i did a pull it was massively under powered... Then i realized he had 3-400lbs in the trunk and the tire size was off...
Old May 17, 2013 | 10:28 PM
tscompusa's Avatar
I'll get more pics if i can yes.
Ya the vd is right. its set to 4.11 gear and tire is correct and stuff. It is done at this power level on stock wiring. If you rewire it, it will be able to make a little more maybe.
is your friends rewired? fuel map has 7's in it uptop its 100% out of fuel. car needs another one of these pumps or a double pump 255 setup.
Old May 18, 2013 | 12:38 AM
Tonba's Avatar
Great power and spool!
How are you finding the R2 cams tscompusa?
Old May 18, 2013 | 04:30 AM
EvocentriK's Avatar
Nice numbers. What's the point of high lift cams +oversize valves with stock head ports? I thought they were maxed flow wise at mid to low 10mm lift.
Old May 18, 2013 | 06:18 AM
HsamehH's Avatar
Tom do you like the R2 cams ,is there a noticable difference than the S2's ?
Old May 18, 2013 | 09:20 AM
browningderek's Avatar
Lookin good! The R2 cams don't slow spool at all... that's awesome! What rpm does the power start to fall? 8300ish?
Old May 18, 2013 | 10:28 AM
CT9Asphixyation's Avatar
I want to begin by saying thanks to Tom for putting in work so that I was able to make it to the track last night. That being said, the trip to the track went a little like this. I teched in at about 8:30, got in line and made my first pass ever with this setup at 9:30. I had NEVER launched the car at this power level before but I still managed a 11.3 @ 133 spinning hard through first and second with a 2.0 60'. Next pass was an 11.9 @ 129 because I missed second. The next pass was an 11.4 at 132 and my final pass before the track closed was an 11.1 @ 133, both with 1.9 60'. Traction is a huge issue as I have continental dws tires on factory pressure. I couldn't drop pressure because my gauge ran out of batteries lol. Track prep is awful on Fridays, no traction compound whatsoever. The car spools like a beast! Full boost by 4700 rpm on a turbo this size is no joke especially considering I'm on a non ported head, stock IM and stock TB. I couldn't be any happier with how my car runs and I cannot wait to get some better tires and upgrade my fuel system. More than satisfied with Toms tune and I would recommend him to anybody. Also fwiw, another forum member on here was indeed riding along with me during the VD pulls in case anybody was wondering.
Old May 18, 2013 | 11:51 AM
5LEEPERISAH23I's Avatar
Question to you, I was trapping the same MPH with the stock Evo 9 FD... i have a 2.4L with now a 4.11 FD.. What RPM were you at going threw the line?
Old May 18, 2013 | 11:59 AM
5leeper-
I honestly wasn't paying much attention to the tach after I shifted into 4th but from what I remember it was around 8300ish.
Old May 18, 2013 | 12:41 PM
juanmedina's Avatar
What was the mph in the 1/8th mile? How much does the car weight?
Old May 18, 2013 | 01:22 PM
BEKevo's Avatar
That is a cleannn engine bay. Can't wait to see what this thing puts down, once you guys fix the fuel supply issue!
Old May 18, 2013 | 03:19 PM
MPH in the 1/8th was 101-103 gaining an average of 30 MPH on the back half. Car is completely stock Evo 9 gsr weight minus emissions stuff and lightweight rims. I weigh 160.
Old May 18, 2013 | 04:00 PM
Time slips
Alright everybody, here's 3 of my time slips from last night.
